Home > Maintenance & Mods (L322) > Quick question on EGR blanking.
hamlet
Ireland 2006 Range Rover HSE Td6 Buckingham Blue
I was having a little look around my engine yesterday and decided while the covers were off I'd blank the EGR.
I made up a disc plate and placed it where the exhaust pas pipe goes into the EGR and is held on with the jubilee type clip.
I'm just wondering if I should also remove and blank the vacuum hose going to the EGR or is it alright just to leave it connected to the valve?
I don't have any errors at the moment and obviously don't want any so didn't want to blank it if there's no need, or no advantage and run the risk of an error popping up.
I'm not sure if it's just the placebo effect but I think it's pulling a little better since fitting, have covered a bit of distance and according to the computer the MPG seem to have also improved also but I'll reserve judgement on this aspect till I've cover more ground.
BTW, it's a 2006 TD6 HSE, many thanks.
Post #426438 5th Feb 2017 4:24pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Yes you need to blank the vacuum pipe, that is whst operates the egr.
you will notice a difference in power and mpg.
get the proper delete conversation valve if you can, don't know how much they are, but really worth it.
Post #426448 5th Feb 2017 5:12pm
hamlet
Thanks for that Greg, I just didn't want to throw up any errors since it's actually physically blanked already I though the operation of the valve wouldn't matter but if the consensus is to blank the vacuum then that's certainly not difficult to do.
Thanks again...... Thumbs Up
Post #426565 6th Feb 2017 2:25pm
You can just screw a brass woodscrew into the end of the vacuum pipe and cable tie it out of the way.
The egr isn't monitored by any ecu, so won't show any fault codes it's a simple mechanical device. Thumbs Up
Post #426570 6th Feb 2017 3:17pm
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
I fitted a blanking kit and now have this error
, (the vacuum line is blanked off)
P0401-20 extended fault path exhaust gas recirculation governor deviation - negative deviation
Post #427256 11th Feb 2017 12:21am
lounge_on_wheels
I fitted a blanking kit and now have this error (2003 TD6)
Post #427257 11th Feb 2017 12:21am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
I would check to see if the vacuum hose is properly blocked or has a leak somewhere. It should not cause any issues if the EGR is removed and the hose capped. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #427259 11th Feb 2017 2:25am
gregdav
That fault I'm sure, always comes up with my iid.
greg.
Post #427260 11th Feb 2017 6:15am
Never had it with mine.
Post #427262 11th Feb 2017 7:20am
lounge_on_wheels
Does yours come up since your blanked the egr? When you say that code always comes up.
Post #427263 11th Feb 2017 7:30am
wayneg
Did you just blank the exhaust side of the egr or fit a EGR delete unit. That code has something to do with airflow and linked with Maf settings according to the BMW forums 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #427276 11th Feb 2017 10:19am
gregdav
The egr was already blanked when I bought the car.
When I had g/box problem, chappy who sorted it read all the codes off his diag tool, I think was a solus.
he picked that fault up as well as others, but cleared thdm all. When I got my bt iid tool, the same fault showed up, so I cleared it again.
now since then I can't remember seeing it, but I have no running issues, maybe I ought to check my vacuum pipes.
Too b Censored y cold at the moment. Brrrrr.
if you haven't any running issues, I wouldn't worry too much.
Greg.
Post #427278 11th Feb 2017 10:28am
wayneg
Have you seen this thread? http://www.fullfatrr.com/forum/post396601.html 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #427371 12th Feb 2017 2:28am
lounge_on_wheels
Yes, I read that and no it is not the cause as I replaced those hoses and it did not fix the problem.
Post #427381 12th Feb 2017 8:29am
MattyB1983
United Kingdom 2004 Range Rover Vogue SE Td6 Java Black
Sorry to jump in but just been out to my car for a look to see if mine had been done prior to me purchasing the car....
I'm guessing mine has been deleted ????
The kits I saw on ebay looked a little different to what is on my car. Is my one ok or should I change it and delete the exhaust part too ??
Also, the two bolts at the top were missing for some reason, can imagine it would of been leaking air. I found a couple of bolts in my garage and fitted them.
Post #427440 12th Feb 2017 2:30pm
