Home > Technical (L322) > Plea for Advice Before My Wife Kills Me... |
b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319 |
http://www.island-4x4.co.uk/fuel-pump-tank...17956.html
29th Jan 2017 2:09pm |
Class_5 Member Since: 01 Jan 2017 Location: Yateley Posts: 29 |
Thanks b348xyx. Noticed that's a Britpart item, are they OK for quality? |
29th Jan 2017 2:38pm |
Hi,
29th Jan 2017 2:48pm |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 |
One relatively cheap solution possibly...
30th Jan 2017 10:44am |
Thanks berkshirelad - It has crossed my mind it could be 'bad' fuel, I've got Green Flag coming out today, so slight hope they might find something (not holding my breath...).
30th Jan 2017 11:36am |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 473 |
As I said, I kept hoping it was something else including bad fuel. It wasn't. Can you hear the pump under the rear seats when you try to start it? Seats up and listen to the offside carpet area under the seat.
30th Jan 2017 6:03pm |
chris - went for a 'mid-point' option, reasonable quality pump and housing (I hope), new seals, locking rings and fuel filter.
30th Jan 2017 8:11pm |
mcspreader Member Since: 28 Jan 2017 Location: cornwall Posts: 57 |
I am not aquainted with the engine and lpg setup but had very similar symptoms on my TVR Tuscan caused by an injector jamming inthe open position. The over fueling causes the lamda to go haywire and it runs like a total pig with no power at all. A sniff around the exhaust (petrol or gas smell which the cat will not be enough to filter) should help identify. As I say not sure but a cheap fix if it is this. It also affects the fuel pump because it cannot maintain pressure as it is constanly bled off by the open injector. |
3rd Feb 2017 6:45pm |
Thanks ever so much for the replies.
3rd Feb 2017 9:48pm |
Glad it's all sorted
3rd Feb 2017 9:53pm |
Great news |
4th Feb 2017 7:08am |
Yes indeed good news, was such a relief yesterday when my wife came home and asked if "it" was fixed, I could answer yes
4th Feb 2017 1:30pm |
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2289 |
Hi, what I don't understand is that you start on lpg... Isn't every system starting on fuel to switch over to lpg autom.
4th Feb 2017 1:55pm |
Hello Robert,
4th Feb 2017 4:05pm |
