Home > Technical (L322) > Battery Recommendations |
steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208 |
Pick one from here.
8th Jan 2017 11:14am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3237 |
This appears to be what most are fitting and from this company: https://www.tayna.co.uk/610-200-Varta-Silv...P3200.html John
8th Jan 2017 11:17am |
Wogger Member Since: 12 Jun 2016 Location: Nottinghamshire Posts: 407 |
I've had a fresh wet cell battery on now for about 2 weeks.
8th Jan 2017 8:31pm |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 |
Bosch S5 is a load of .... I had lots of issues and 2 replacements, then was advised about AGM and I've not seen a flat battery since.
8th Jan 2017 9:01pm |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 |
This looks a good L322 AGM battery at a fair price.
8th Jan 2017 9:09pm |
unsolicited Member Since: 30 May 2016 Location: Bucks Posts: 128 |
I've had that H15 in for a few months now. No problems yet*
9th Jan 2017 6:52pm |
Walshy Member Since: 18 Dec 2016 Location: Nottingham Posts: 8 |
Had the AA around to jump start me and test the battery and alternator and they are both fine 😕.
9th Jan 2017 7:57pm |
Joncey Member Since: 24 May 2014 Location: St Helier Posts: 53 |
I have been using one of these battery's since around October and no problems but only time will tell if it's truly up to the job |
9th Jan 2017 10:52pm |
Ginja Member Since: 17 Mar 2016 Location: England Posts: 26 |
I think I'm suffering from a cold battery running the heater in the morning as well. Quite often getting the 'click' noise from the engine but wait 10 seconds and it will start - battery not recovering quick enough I think.
22nd Jan 2017 3:38pm |
KRV24 Member Since: 02 May 2016 Location: Berkshire Posts: 35 |
Had the dreaded one click too many before the FFRR fired up yesterday morning , so you can tell where this is going. Fired up fine in the evening on way from home but the relatively short journeys coupled with heated seats, heated steering wheel,lights,front and back demisters, heating etc etc, the dreaded click became two and then nothing
26th Jan 2017 9:41pm |
Had a go at fitting a spare 020 battery (Bosch one, as it happens - but that doesn't matter), which I had for my 2002 TD6 into my 2010 TDV8. It was always a tight squeeze in the TD6, but it does not fit the 2010.
26th Jan 2017 10:01pm |
Cheers Steveball
26th Jan 2017 11:00pm |
lazylabs Member Since: 01 Nov 2016 Location: Lincoln Posts: 78 |
Just replaced my 019 battery with the Varta I5 silver 020. Much better performance on starting and even got my tv picture back (although suspect this was due to hard resetting everything).
27th Jan 2017 4:30pm |
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541 |
I have the original battery in mine and white using the FBH heated seat/ wheel etc for the last month or so it seems to be giving up the ghost slowly, went out today to check it as it hadn't been on the CTek and it read 10.5 on the multi meter and just clicked when trying to start ( what is this about one click, two clicke etc I've read above?)
27th Jan 2017 5:57pm |
