![]() | Home > Technical (L322) > Battery Recommendations |
steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208 ![]() ![]() ![]() |
Pick one from here.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3247 ![]() ![]() ![]() |
This appears to be what most are fitting and from this company: https://www.tayna.co.uk/610-200-Varta-Silv...P3200.html John
Wogger Member Since: 12 Jun 2016 Location: Nottinghamshire Posts: 407 ![]() ![]() ![]() |
I've had a fresh wet cell battery on now for about 2 weeks.
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
Bosch S5 is a load of |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
This looks a good L322 AGM battery at a fair price.
unsolicited Member Since: 30 May 2016 Location: Bucks Posts: 128 ![]() ![]() ![]() |
I've had that H15 in for a few months now. No problems yet*
Walshy Member Since: 18 Dec 2016 Location: Nottingham Posts: 8 ![]() ![]() ![]() |
Had the AA around to jump start me and test the battery and alternator and they are both fine 😕.
Joncey Member Since: 24 May 2014 Location: St Helier Posts: 53 ![]() ![]() ![]() |
I have been using one of these battery's since around October and no problems but only time will tell if it's truly up to the job |
Ginja Member Since: 17 Mar 2016 Location: England Posts: 26 ![]() ![]() |
I think I'm suffering from a cold battery running the heater in the morning as well. Quite often getting the 'click' noise from the engine but wait 10 seconds and it will start - battery not recovering quick enough I think.
KRV24 Member Since: 02 May 2016 Location: Berkshire Posts: 35 ![]() ![]() ![]() |
Had the dreaded one click too many before the FFRR fired up yesterday morning |
Had a go at fitting a spare 020 battery (Bosch one, as it happens - but that doesn't matter), which I had for my 2002 TD6 into my 2010 TDV8. It was always a tight squeeze in the TD6, but it does not fit the 2010.
Cheers Steveball |
lazylabs Member Since: 01 Nov 2016 Location: Lincoln Posts: 78 ![]() ![]() ![]() |
Just replaced my 019 battery with the Varta I5 silver 020. Much better performance on starting and even got my tv picture back (although suspect this was due to hard resetting everything).
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541 ![]() ![]() ![]() |
