Home > In Car Electronics (L322) > Replacing Cigar Lighter with USB
markcartlidge
I was getting annoyed with my cigar lighter socket not giving my phone enough juice on navigation so I decide to upgrade the lighter socket with one of these.
, got it off ebay.
Now fitted it and seems a lot better. I will have to monitor the battery to make sure it isn’t causing any significant drain but looks good so far.
[/url]
Post #424003 20th Jan 2017 6:02pm
Rob99
Looks handy. Do you have an eBay link Mark? Thumbs Up 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #424035 20th Jan 2017 10:14pm
pietertje
Netherlands 2002 Range Rover Vogue 4.4 V8 Java Black
I ordered a green one...
https://pl.aliexpress.com/item/12V-Car-Mot...98085d7337 2002 L322 V8
Post #424054 21st Jan 2017 12:10am
markcartlidge
this is where i ordered.
http://www.ebay.co.uk/itm/302025267353?_tr...ebidx%3ait
the standard cigar lighter has two different size spade connectors so you will need to fix the wiring slightly.
you might find them cheaper elswhere.
i have also order this one which hasnt arrived yet
http://www.ebay.co.uk/itm/401123127422?_tr...ebidx%3ait
Post #424064 21st Jan 2017 1:36am
scuddriver
United Kingdom 2011 Range Rover Vogue 4.4 V8 Java Black
Sounds like a good idea, however, how do I get the old one out? I guess it might mean removing the central console?
TDV8 4.4 2011
 2011 Vogue TDV8 4.4
1992 Mazda Mx5
Post #424098 21st Jan 2017 2:55pm
markcartlidge
On my 2002 it was quiet simple. Take a look at powerfuluk.com to see if they have any videos on how to do it. That's where I learnt how to do mine.
Post #424100 21st Jan 2017 3:07pm
scuddriver
Thanks that site is certainly worth a look, but they haven't done a fitting video yet.
"These ashtrays are screwed in place but you will first need to remove the upper trim"
http://www.powerfuluk.com/vehicles/range-r...-2012.html 2011 Vogue TDV8 4.4
1992 Mazda Mx5
Post #424104 21st Jan 2017 3:39pm
scuddriver
A bit more frreting on that site, and there is a video (featuring cam tech Craig) which shows how to remove the trim.
http://www.powerfuluk.com/vehicles/range-r...nuine.html 2011 Vogue TDV8 4.4
1992 Mazda Mx5
Post #424105 21st Jan 2017 3:47pm
scuddriver
But having removed the central console to gain access the the cigar lighter in the ashtray, I found the new one wouldn't fit. It has a wider diameter than the original, which would mean somehow widening the aperture, and that is something I wasn't prepared to do. 2011 Vogue TDV8 4.4
1992 Mazda Mx5
Post #427971 16th Feb 2017 11:20am
markcartlidge
Understandable with an 11 plate. my 02 I was less concerned and used this http://www.toolstation.com/shop/Power+Tool...ill/p61469 with a little opening up after and it fitted.
Post #427976 16th Feb 2017 11:27am
its much easier to fit one of these, only £1'ish from ebay,
Post #427978 16th Feb 2017 11:34am
markcartlidge
I had several of those but they are usually lower rating and my phone was losing charge when used as sat nav. With my 4.2A I am a happy man. phone actually charges now when being satnav.
Post #427981 16th Feb 2017 11:52am
I've found the same thing - the ones that fit flush all seem to be 1A per output.
Anything with 2.1A outputs sticks out a bit further - and some devices need the higher current/power to charge properly.
That said - I just live with one sticking out a bit.....
Post #427982 16th Feb 2017 12:09pm
JPHC
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
I have one of those flush dual port thingies. Looks great but two iphones cant charge at the same time...does the job otherwise Jordan
'56 SC 4.2 ‘21-Current
'56 SC 4.2 ‘16-‘18
Post #427983 16th Feb 2017 12:11pm
you'all want one of these then, only £4.71 .........and it comes with a spare 'tyre' as well Laughing
http://www.ebay.co.uk/itm/USB-CAR-CHARGER-...Swax5Yo45l
Post #427987 16th Feb 2017 1:56pm
