![]() | Home > In Car Electronics (L322) > Replacing Cigar Lighter with USB |
markcartlidge Member Since: 18 Mar 2013 Location: Nr Winslow, Buckinghamshire Posts: 120 ![]() ![]() ![]() |
I was getting annoyed with my cigar lighter socket not giving my phone enough juice on navigation so I decide to upgrade the lighter socket with one of these.
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1457 ![]() ![]() |
Looks handy. Do you have an eBay link Mark? |
pietertje Member Since: 30 Nov 2014 Location: Rotterdam Posts: 152 ![]() ![]() ![]() |
I ordered a green one...
this is where i ordered.
On my 2002 it was quiet simple. Take a look at powerfuluk.com to see if they have any videos on how to do it. That's where I learnt how to do mine. |
scuddriver Member Since: 12 Feb 2015 Location: Dunbar Posts: 140 ![]() ![]() ![]() |
Thanks that site is certainly worth a look, but they haven't done a fitting video yet.
A bit more frreting on that site, and there is a video (featuring cam tech Craig) which shows how to remove the trim.
But having removed the central console to gain access the the cigar lighter in the ashtray, I found the new one wouldn't fit. It has a wider diameter than the original, which would mean somehow widening the aperture, and that is something I wasn't prepared to do. 2011 Vogue TDV8 4.4
Understandable with an 11 plate. my 02 I was less concerned and used this http://www.toolstation.com/shop/Power+Tool...ill/p61469 with a little opening up after and it fitted. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35599 ![]() ![]() |
its much easier to fit one of these, only £1'ish from ebay,
I had several of those but they are usually lower rating and my phone was losing charge when used as sat nav. With my 4.2A I am a happy man. phone actually charges now when being satnav. |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7998 ![]() ![]() ![]() |
I've found the same thing - the ones that fit flush all seem to be 1A per output.
JPHC Member Since: 07 Sep 2015 Location: Kent Posts: 303 ![]() ![]() ![]() |
I have one of those flush dual port thingies. Looks great but two iphones cant charge at the same time...does the job otherwise Jordan
you'all want one of these then, only £4.71 .........and it comes with a spare 'tyre' as well |
