Home > Technical (L322) > My lower tail gate seems to stick intermittently
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
2003 L322 lower tailgate sticks intermittently, I sometimes cannot open it by pressing the button on the bottom tail gate, after a few goes it'll open. I can hear the actuator working. Is this a common problem with this model, whats the remedy?
thanks
Post #423730 19th Jan 2017 11:34am
proser
i would start with lubricating the locks on each side. Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #423734 19th Jan 2017 12:14pm
RP123
Scotland 2006 Range Rover HSE Td6 Bonatti Grey
HI
Could also take the inside panel out - lots of joints inside that can be lubed.
and…. not sure if you know,
but there are a couple of emergency 'levers' that can be pushed down to release manually.
Not a great photo but you can see the lever on the top. When the tailgate is shut there is just enough room to get a finger down there and press the lever (need to both sides) - Might help if it sticks again
Cheers
Simon
Post #423744 19th Jan 2017 12:59pm
RP123
oops also meant to say check the lock pins- (what ever they are called lol) (the things that stick out from the body) as if they may be out of alignment.
Simon
Post #423745 19th Jan 2017 1:03pm
lounge_on_wheels
Thanks guys
Post #423843 19th Jan 2017 8:09pm
lounge_on_wheels
Sprayed some WD40 on the locks and all is good, thanks for the advice on the emergency levers, found them.
Post #424067 21st Jan 2017 2:16am
RP123
Post #424082 21st Jan 2017 10:17am
