Home > Technical (L322) > Toothed belt change 2011 4.4 TDV8
Webbie
Owned my FF for eight months, trouble free I thought until now. The cars in for service at an independent, being due an inspection 1 with 64000 on the clock. The machinic has noticed the toothed belt is starting to slip off it's pully, it's the belt which drives the power steering and alternator. I have authorised it to be replaced and the garage are awaiting parts.
Wondering:
When should the belt noramally be replaced?
Was it missed off a previous service.
Should all of the pulleys be replaced at the same time?
Is it a known issue on the 4.4 TDV8?
Post #423385 17th Jan 2017 8:57pm
Baltic Blue
Someone with a better memory than me will direct you to a post by Craig some while ago describing the problem with the toothed belt guide, causing it to run off line. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #423387 17th Jan 2017 9:09pm
it is likely the pulley its slipping off is the tensioner. According to craig, the tensioners were prone to failure, the symptom of which is the belt running half off the pulley.
its pretty easy to change the tensioner. I reckon its doable on the drive with a couple of spanners and some skinned knuckles.
I have just had my ribbed belt done, while the front of my car was apart for something different. it had started to squeak a bit. IN theory the belts are fitted for life, but thats just bollo Censored
the belt on its own is about £35 from LR.
its not a regular service item neither are the pulleys. Get the tech to check all the pulleys are running free and if its the tensioner at fault get that changed too. There is nothing that can't be fixed with a hammer😜😜
Post #423391 17th Jan 2017 9:26pm
Webbie
Thank you gents for responding, I feel a bit better informed now. The garage are intimating a bill of about £360 all in to do the belt job on top of the service. I can't work out why they work out why they feel they want to replace all of the pulleys just because tha have a bit of surface rust.
Post #423403 17th Jan 2017 10:04pm
most of the pulleys are plastic Whistle but tbh if they are replacing them all for that they are doing well, as I priced them up recently and the price for the parts was more than that. I would expect that sort of bill for just doing the belt and the tensioner, and the couple of pulleys you can get to easily. Stripping the other pulleys out is a bit more involved and many hours labour as one of them is on the alternator mounting bracket. There is nothing that can't be fixed with a hammer😜😜
Post #423405 17th Jan 2017 10:10pm
Webbie
Thanks for the additional info. It's my first RR and my first time at this Indy, always guarding against being taken for a ride with any garage having bad experiences in the past. Think this should be OK.
Post #423413 17th Jan 2017 10:33pm
666tur
United Kingdom 2012 Range Rover Vogue SE TDV8 Zambezi Silver
My 2012 4.4 has started squeaking likes it slipping, noticed the belt is half off the tensioner too. Need to get it looked at. 2012 4.4TDV8 VSE
2004 TD6 132k miles- SOLD
1995 Land Rover Defender 110 Tithonus Ex Military
1995 Land Rover Discovery 3.9i V8 manual
Post #469407 19th Feb 2018 8:53pm
GGDR
I was advised to change the idler pulley(s) if in doubt. Because if the belt goes it will cause collateral damage.
Worth a peek with a torch once a month for all of us for sure. If the belt's half off then time to act!
. Cheers, Greg
Post #469425 20th Feb 2018 7:02am
carpcat
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Tensioner and both belts changed on mine when the belt slipped off 2 weeks ago. No collateral damage luckily. Tensioner bearings collapse and throws the belt off. I had a strange whirring noise beforehand which I put down to the belt, but now realise it was probably the tensioner bearings on their last legs. First thing I knew the battery light came up on the dash, and power steering stopped working. Recovered to garage to fix. Chris
Post #469426 20th Feb 2018 7:08am
666tur
I am taking it into deals next week. I am assuming the tensioner is covered under the extended warranty. Mine is squeak, a spray of water quietens it for a bit. I am now nervous of it going now. Does anyone know how access able the tensioner and bolts are? It looks quite tight. 2012 4.4TDV8 VSE
Post #469455 20th Feb 2018 2:02pm
carpcat
My invoice was about 6 Hours work as the top coolant hose and fan cowling had to be removed, plus approx £200 parts Chris
Post #469466 20th Feb 2018 3:18pm
666tur
My car has been to the dealer. It requires a new tensioner and it is covered by the extended warranty. 2012 4.4TDV8 VSE
Post #470268 27th Feb 2018 3:18pm
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Does anyone have any pictures of what I should be looking for ?
My belt squeaks a little for a minute after startup, then quietens down. Would be handy to check it though. Confused Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #470324 27th Feb 2018 11:43pm
666tur
My car is at dealer so can’t get a picture. If you stand at the front looking towards engine, there is a gap on the right hand side between engine and radiator, get a torch and inspect the belt, look at the second pulley from the top, it is the tensioner and has no lip on the pulley wheel unlike the others. On mine the belt was running at least 20% off the this pulley wheel. The dealer said not to drive like this, if it fails there is 1metre of strong belt thrashing around in there. 2012 4.4TDV8 VSE
Post #470343 28th Feb 2018 8:43am
John w
OK, thanks. I will take a look at the weekend. Thumbs Up Too many toys, not enough time
Post #470381 28th Feb 2018 1:26pm
