![]() | Home > Maintenance & Mods (L322) > Scissor lift for garage/workshop |
fanders Member Since: 10 Jul 2013 Location: Hants, UK Posts: 318 ![]() ![]() ![]() |
I'm building a new garage at the moment and would like to install a scissor lift for raising vehicles when working on them (not enough room for a two-post lift). Does anyone have experience of lifting the L322 on a scissor lift? I'd be interested to know about any issues involved.
Plenty of Kwik Fit tyre places use those. Mine has been on them a number of times without issue |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 ![]() ![]() ![]() |
They look like a great addition to have in your garage!
Yep, mine has the side tubes - perhaps I will have to take those off when working on it?
Possibly, just thinking about the weight of the car on them, and the possibility of scratching and denting them! |
They use rubber and wooden blocks on the jacking points in Kwik Fit. Wood to get the thickness so nothing fouls and then a rubber on top to cushion it all. |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
I believe that Vikash had one installed in his garage ..... not sure if he's still on here, but his profile is there so you should be able to contact him by pm |
daveenty Member Since: 30 Mar 2016 Location: North West Posts: 34 ![]() ![]() |
I have one of THESE in my garage.
Looks good daveenty! |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1459 ![]() ![]() |
Looks a nifty piece of kit but this one is rated at 3 tonnes so not suitable for an L322 weighing in at around 3.3 tonnes 2021 D350 Fifty Edition - Carpathian Grey 2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black 2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black |
ndg Member Since: 25 Mar 2016 Location: Warwickshire Posts: 94 ![]() ![]() ![]() |
L322's are for a 2.5tonnes.... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35608 ![]() ![]() |
the diesel L322 is 5975 lbs [2.66 tons]
Will do. Hopefully tomorrow as I want to give it a wheels off clean up before a little trip on Sunday. As I mentioned, I'm height restricted with the interior, though should be able to get the wheels to shoulder height which is usually enough for my needs. Another couple of shots when I was initially trying it, and before I finished the garage off. The Jeep's not at full height here but the Merc is about as far as it will go before the bonnet catches a light.
2010 5.0 Autobiography |
builder1966 Member Since: 23 Aug 2016 Location: ashingdon Posts: 299 ![]() ![]() ![]() |
I have a county 4 post lift even though I don't do the work on my rangies best investment ever in a garage forsure use it more than the pit tbh |
