Home > Maintenance & Mods (L322) > Scissor lift for garage/workshop
Page 3 of 3 <123
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Ahh. Thought it would be something like that.
Cheers john.
Post #422257 11th Jan 2017 9:46pm
miggit
Whistle Those don't work as well as they should... they tend to run out of lift before the wheels get off the ramp... by experiment it was found to be an advantage to start in high mode and use some large packers... where as a 2 post lift is by far a better option, except you don't have as much storage space for the bits coming off Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #422258 11th Jan 2017 9:47pm
Yes an air operated jacking beam
Post #422262 11th Jan 2017 9:53pm
Weegie
Lovely setup. Thumbs Up John
GAP iiD BT-Sold
Post #422263 11th Jan 2017 9:55pm
gregdav
Food for thought.
nice set up. Thumbs Up
Maybe one day, I'll get a nice garage, with a painted floor. Wink
Post #422278 11th Jan 2017 10:46pm
Floor paint isn't worth the hassle, it peels due to the hot tyres sitting on top of it and cooling down. Plastic tiles are the way to go
Post #422318 12th Jan 2017 12:52am
ajac8
Jealous me? noooo Whistle 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #422462 12th Jan 2017 9:07pm
Ginja
I have the green strongman clifton as shown in the first post in my garage - had it since Feb last year. I don't use it very much but its important when I do. It was able to lift my 2005 Dodge Ram which believe it or not is a similar weight to an L322. It comes in a forklift style wooden box which contrary to the video you cannot remove the raised forklift sections from so getting it out of the box was a nightmare. Had to cut the box off while supporting and lowering it from two jacks. You can move it about the place if you are strong and mine at least came with the hydraulic fluid as well, you just need the correct power supply and off you go.
I strongly suspect its a made in china jobbie but its certainly stoutly constructed and gives confidence.
Post #424583 24th Jan 2017 4:56pm
Reach
United States
I've got an inexpensive Chinese made 2-post lift designed for low ceilings. I've got 9'3" height in the garage, and these posts come in just over 9', fit without modification. 8000lbs load certified, had no problem lifting the Rover. Mostly I use it for low-and-light sports cars which it can lift high enough for me to sit comfortably under and work on, but with the RR I can get the wheels about 6" off the ground with the garage door open, or 24" off the ground with the door shut.
So, don't rule out the 2 poster entirely. I don't know who would sell them on your side of the pond, but they're pretty easy to get over here.
Post #424754 25th Jan 2017 4:13pm
miggit
Whistle Strongman Tools do a 4 Ton 2 post lift that's almost a thousand ponds cheaper than that scissor lift, and is far more useful Thumbs Up
Reach is your garage detached from the house? if so I'd be tempted to give it a pitched roof Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #424814 26th Jan 2017 12:07am
Page 3 of 3 <123
