Home > Maintenance & Mods (L322) > Scissor lift for garage/workshop
Page 1 of 3 123>
fanders
United Kingdom 2009 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
I'm building a new garage at the moment and would like to install a scissor lift for raising vehicles when working on them (not enough room for a two-post lift). Does anyone have experience of lifting the L322 on a scissor lift? I'd be interested to know about any issues involved.
I'm probably going to buy one of these: http://sm-t.co.uk/wp-content/uploads/2015/...Spec_H.pdf
Cheerio, fanders
Post #421397 6th Jan 2017 12:21pm
mzplcg
Plenty of Kwik Fit tyre places use those. Mine has been on them a number of times without issue
Post #421398 6th Jan 2017 12:32pm
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
They look like a great addition to have in your garage!
Does your car have the metal side bars like mine?
If so, i'm not sure if they will cause a problem or not?!
Post #421401 6th Jan 2017 12:41pm
fanders
Yep, mine has the side tubes - perhaps I will have to take those off when working on it?
Post #421402 6th Jan 2017 12:48pm
Stacker
Possibly, just thinking about the weight of the car on them, and the possibility of scratching and denting them!
Post #421403 6th Jan 2017 12:49pm
mzplcg
They use rubber and wooden blocks on the jacking points in Kwik Fit. Wood to get the thickness so nothing fouls and then a rubber on top to cushion it all. Thumbs Up
Post #421420 6th Jan 2017 2:32pm
miggit
I believe that Vikash had one installed in his garage ..... not sure if he's still on here, but his profile is there so you should be able to contact him by pm Thumbs Up
Whistle if you look at the thread "man cave" you can see his lift Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #421443 6th Jan 2017 4:02pm
daveenty
I have one of THESE in my garage.
Mainly used for lifting the Merc to clean it, though I will be putting the RR on it for wheel changes, routine maintenance etc. The biggest cost was raising the ceiling to accommodate the car roof going through it, but it's well worth doing for the time it saves in jacking it up and walking round it.
Mine came with 4 small rubber blocks, though I acquired some bigger ones from the bay of dreams as I didn't really have confidence using timber due to the small footprint it lifts on.
Not had the Range Rover on it yet (the Mercedes has been up on it for the last few weeks with it's wheels off) but it lifted my old Jeep GC without an issue so it should be fine.
FWIW I have no side bars or steps on mine, so it should theoretically be a lot easier to raise it...
Picture below is about the highest I could get the Jeep, though it made it easier to work on, especially when scooting round on a little wheeled stool. Smile
 Dave
2010 5.0 Autobiography
Post #421447 6th Jan 2017 4:19pm
fanders
Looks good daveenty! Thumbs Up Please paste up some pictures of the FFRR when it's up on your lift.
Post #421455 6th Jan 2017 4:57pm
Rob99
Re: Scissor lift for garage/workshop
Looks a nifty piece of kit but this one is rated at 3 tonnes so not suitable for an L322 weighing in at around 3.3 tonnes 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #421461 6th Jan 2017 5:42pm
ndg
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
L322's are for a 2.5tonnes....
Post #421470 6th Jan 2017 6:11pm
the diesel L322 is 5975 lbs [2.66 tons]
the petrol is 5710 lbs [2.55 tons]
thats unladen and with a full tank of fuel [2010-2012]..
Post #421473 6th Jan 2017 6:18pm
daveenty
Will do. Hopefully tomorrow as I want to give it a wheels off clean up before a little trip on Sunday.
As I mentioned, I'm height restricted with the interior, though should be able to get the wheels to shoulder height which is usually enough for my needs.
Another couple of shots when I was initially trying it, and before I finished the garage off. The Jeep's not at full height here but the Merc is about as far as it will go before the bonnet catches a light.
 Dave
Post #421476 6th Jan 2017 6:31pm
builder1966
England 2004 Range Rover Vogue Td6 Adriatic Blue
I have a county 4 post lift even though I don't do the work on my rangies best investment ever in a garage forsure use it more than the pit tbh
Post #421478 6th Jan 2017 6:33pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Be careful.... the type shown in the OP picture are sometimes not long enough to meet front and rear jacking points together. i am looking to do the same and some of the cheaper ebay ones (£1k mark) are simply not long enough even those rated at 4tonnes. Big Cry
I would have to consider some form of steel square section lengths placed on top of the ramps but overhanging the ramps each end. these could have holes in them to accept the rubber feet if the feet have bars attached to them which many seem to. 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #421483 6th Jan 2017 6:52pm
Page 1 of 3 123>
