Home > Technical (L322) > Problem |
steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208 |
Start with the obvious - do you definitely have plenty of fuel?
3rd Jan 2017 10:52pm |
GDM Member Since: 21 Nov 2016 Location: West Sussex Posts: 165 |
Start by getting the fault codes checked. |
3rd Jan 2017 10:55pm |
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 744 |
Car was low on fuel yesterday! I don't normally let the light come on! Put £50 in and it went to half tank! Car has done15 miles since adding fuel! Could I have pulled dirt through and clogged the filter resulting in non starting!!
3rd Jan 2017 11:00pm |
Plugged my IID in and didn't see anything thing relating to problem!
3rd Jan 2017 11:01pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8507 |
when was the last time the fuel filter was changed? other than that it sounds fuel pump related, possibly lift pump in the tank. There is nothing that can't be fixed with a hammer😜😜
3rd Jan 2017 11:17pm |
Car still in garage! Thought the battery had gone so have replaced it!
8th Jan 2017 3:02pm |
Black smoke indicates over-fuelling or severe restriction of air intake - basically extremely rich mixture. If that's sounds like what you saw, look for injector(s) stuck and pouring too much fuel into cylinder.
8th Jan 2017 3:50pm |
Mechanic has just called! Reckons that when he removes the oil filler cap the car runs! Put it back on and car builds up pressure and stops !
8th Jan 2017 4:03pm |
Not sure that is the answer, and why it runs as he is saying... anyhow someone with more nouse than me will probably have a better idea. Wonder if there is a crankcase breather problem. The crankcase breather/separator is located next to the oil cooler in the vee (behind the oil filter housing) maybe worth checking first.
8th Jan 2017 4:50pm |
Thanks 2014 vogue se |
8th Jan 2017 4:53pm |
Update!!
17th Jan 2017 8:18pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1751 |
17th Jan 2017 9:56pm |
Let's hear it for Mikey 2014 vogue se |
17th Jan 2017 10:03pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
Any idea of the cause Mikey? Too much turbo bearing movement or foreign object in the turbo? ______________________________
18th Jan 2017 9:08pm |
