Home > Technical (L322) > Problem
Page 1 of 4 1234>
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
Problem
Going to work tonight, car pulling fine then just lost all power! Restarted and ran for 5 seconds then died!!
Now won't fire up!
Any ideas??
TIA
David 2014 vogue se
Post #421046 3rd Jan 2017 10:45pm
steveball
United Kingdom 2010 Range Rover Vogue SE TDV8 Bournville
Start with the obvious - do you definitely have plenty of fuel?
Then start looking at fuel pumps. On the TD6 there was a low pressure one under the sill by the back door and a high pressure one in the engine bay. Presume TDV8 is similar.
Failing that, time to look at injectors I guess, though it would be very unusual for the, to fail suddenly when the engine is running.
None of these easy fixes on the side of the road, though - unless you've been careless and run out of fuel. Current: 2010 Range Rover L322
Vogue SE, TDV8 3.6, Bournville
Now gone: 2002 Range Rover L322
Vogue, TD6, Giverney Green
Post #421052 3rd Jan 2017 10:52pm
GDM
United Kingdom 2006 Range Rover Vogue Td6 Zambezi Silver
Re: Problem
Now won't fire up!
Any ideas??
TIA
David
Start by getting the fault codes checked.
Post #421053 3rd Jan 2017 10:55pm
chefkenmore
Car was low on fuel yesterday! I don't normally let the light come on! Put £50 in and it went to half tank! Car has done15 miles since adding fuel! Could I have pulled dirt through and clogged the filter resulting in non starting!!
Car has gone to garage on the back of the AA!! Second time in two months................................. burst airbag the first time round!
David 2014 vogue se
Post #421054 3rd Jan 2017 11:00pm
chefkenmore
Plugged my IID in and didn't see anything thing relating to problem!
Only the usual candidates! 2014 vogue se
Post #421055 3rd Jan 2017 11:01pm
when was the last time the fuel filter was changed? other than that it sounds fuel pump related, possibly lift pump in the tank. There is nothing that can't be fixed with a hammer😜😜
Post #421057 3rd Jan 2017 11:17pm
chefkenmore
Car still in garage! Thought the battery had gone so have replaced it!
On firing up this morning it turned over but just filled the garage with smoke!!
Nothing showing up on diagnostics!
Any ideas?? 2014 vogue se
Post #421758 8th Jan 2017 3:02pm
steveball
Black smoke indicates over-fuelling or severe restriction of air intake - basically extremely rich mixture. If that's sounds like what you saw, look for injector(s) stuck and pouring too much fuel into cylinder.
White smoke tends to indicate water in the cylinders - so check compression, possible head gasket (or possibly, water in fuel).
Blue smoke tends to indicate the presence of excessive amounts of engine oil in the cylinder. Start looking at compression, perhaps piston rings. Current: 2010 Range Rover L322
Post #421763 8th Jan 2017 3:50pm
chefkenmore
Mechanic has just called! Reckons that when he removes the oil filler cap the car runs! Put it back on and car builds up pressure and stops !
He now thinks that one of my turbos has gone! Is that a huge job and is it worth replacing the other one at the same time ?? 2014 vogue se
Post #421765 8th Jan 2017 4:03pm
Not sure that is the answer, and why it runs as he is saying... anyhow someone with more nouse than me will probably have a better idea. Wonder if there is a crankcase breather problem. The crankcase breather/separator is located next to the oil cooler in the vee (behind the oil filter housing) maybe worth checking first.
In terms of if it is the turbos, then one is easier than the other I think and Mikey is probably the best chap to advise as he has done a few iirc. It's not a "Small" job but it's been done by quite a few on this engine now and is probably worth getting both done if you are going to keep it, also get the EGR valves checked over as they can be the cause of the failures in the first instance. There is nothing that can't be fixed with a hammer😜😜
Post #421770 8th Jan 2017 4:50pm
chefkenmore
Thanks Thumbs Up 2014 vogue se
Post #421771 8th Jan 2017 4:53pm
chefkenmore
Update!!
Conclusion is that indeed, one of my turbos has gone!! Local Indy doesn't want to do the job! Too time consuming, quoting £6000!!
Car being lifted in the the next couple of days and taken to Mikey! Thumbs Up
Both turbos being replaced and " other bits "
Thanks for helping!
Now we will see how good Olympic Warranties are? I paid extra to cover the turbos Rolling with laughter Rolling with laughter Rolling with laughter 2014 vogue se
Post #423375 17th Jan 2017 8:18pm
Mikey
Plenty of practice Laughing Thumbs Up
Smart money is on the NS turbo having shat itself...
Post #423399 17th Jan 2017 9:56pm
chefkenmore
Let's hear it for Mikey Bow down 2014 vogue se
Post #423402 17th Jan 2017 10:03pm
rar110
Any idea of the cause Mikey? Too much turbo bearing movement or foreign object in the turbo? ______________________________
Post #423592 18th Jan 2017 9:08pm
Page 1 of 4 1234>
