![]() | Home > Technical (L322) > New windscreen not OEM now no auto lights FIXED |
Robgosty Member Since: 20 Dec 2013 Location: Manchester Posts: 232 ![]() ![]() ![]() |
[url]Hi all screen replaced with non Pilkington one and auto lights not working, replaced sensor pad and tried new sensor with no joy as read on another thread problem is caused by sensor pad, has anyone found a fix for this as it can't be just me who has this problem[/url] |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
Well, not sure if its the same problem but when I had this identical scenario it turned out that the fitting behind the mirror that contains the light and rain sensors had not been clipped properly to the screen, so it was slightly proud of the glass and didn't work. Fitter returned, removed and refitted the sensor and clamp, and was fixed. Graham
Presumably you didn't fit the screen yourself so call the fitter and ask them to come and sort it.
Fitter is a friend and no wiser than me, googled and other people have had same issue when non Pilkington screen fitted, one guy replaced sensor pad as had bubbles in it but this has not worked for me, only a little niggle but it annoys the hell out of me, at night turn engine on and lights come on for about 20 seconds they then go off for about 30 sec then come back on again, in daylight lights are on all the time, this has only happened since screen was replaced, if I just hold sensor on screen during day lights go off fine, thinking of just removing purple part that is attached to screen and drilling a hole in it 🤔 |
Hi Alistair, not an insurance job, have a trader policy so don't want to be claiming on that, just needing a fix for the problem, some one must have a clue |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Ian it aligned properly with the little window in the top hatching area? If the glass is fitted slightly off then it might be out of line. There is nothing that can't be fixed with a hammer😜😜
Bit the bullet and bought new sensor and pad from e-bay, bastards still the same, removed pad and lens and just fixed sensor to glass with double sided tape, lo & behold auto lights working fine, run a bead of silicon round edge, all good, can only presume purple lens is to do with auto wipers (turned mine off with IOD tool as crap) just happy auto lights is back to normal |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8001 ![]() ![]() ![]() |
Glad to hear you resolved it |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8549 ![]() ![]() ![]() |
Mine are excellent, barely have to interfere at all, maybe your auto wiper sensor is faulty as well...!!! Glad the lights are fixed ![]() __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
So was it more or less what I suggested ^^^ ... not fitted to the screen properly...? Graham
Not really as auto lights were on all the time with lens in place, now it's removed and sensor fitted direct to screen lights work fine, as I said can presume the purple lens is just to do with autowipers which I have turned off |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1559 ![]() ![]() |
I posted some pics in a couple of other threads but I can't link the post as I can't quote it. See http://www.fullfatrr.com/forum/topic36415-60.html
