Home > Technical (L322) > New windscreen not OEM now no auto lights FIXED
Robgosty
[url]Hi all screen replaced with non Pilkington one and auto lights not working, replaced sensor pad and tried new sensor with no joy as read on another thread problem is caused by sensor pad, has anyone found a fix for this as it can't be just me who has this problem[/url]
Post #420735 2nd Jan 2017 2:21pm
A1GSS
Well, not sure if its the same problem but when I had this identical scenario it turned out that the fitting behind the mirror that contains the light and rain sensors had not been clipped properly to the screen, so it was slightly proud of the glass and didn't work. Fitter returned, removed and refitted the sensor and clamp, and was fixed. Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #420736 2nd Jan 2017 2:28pm
mzplcg
Presumably you didn't fit the screen yourself so call the fitter and ask them to come and sort it.
If done via insurance I would complain to them so they can log the complaint with the fitters.
Post #420743 2nd Jan 2017 3:28pm
Robgosty
Fitter is a friend and no wiser than me, googled and other people have had same issue when non Pilkington screen fitted, one guy replaced sensor pad as had bubbles in it but this has not worked for me, only a little niggle but it annoys the hell out of me, at night turn engine on and lights come on for about 20 seconds they then go off for about 30 sec then come back on again, in daylight lights are on all the time, this has only happened since screen was replaced, if I just hold sensor on screen during day lights go off fine, thinking of just removing purple part that is attached to screen and drilling a hole in it 🤔
Post #420749 2nd Jan 2017 4:05pm
Isn't a windscreen covered on your insurance ?
I had a new Pilkington one fitted and it cost me something like £80 for the windscreen excess - and doesn't count as a claim....
Post #420757 2nd Jan 2017 4:36pm
Robgosty
Hi Alistair, not an insurance job, have a trader policy so don't want to be claiming on that, just needing a fix for the problem, some one must have a clue Thumbs Up
Post #420776 2nd Jan 2017 5:52pm
Ian it aligned properly with the little window in the top hatching area? If the glass is fitted slightly off then it might be out of line. There is nothing that can't be fixed with a hammer😜😜
Post #420778 2nd Jan 2017 6:07pm
Robgosty
Re: New windscreen not OEM now no auto lights FIXED
Bit the bullet and bought new sensor and pad from e-bay, bastards still the same, removed pad and lens and just fixed sensor to glass with double sided tape, lo & behold auto lights working fine, run a bead of silicon round edge, all good, can only presume purple lens is to do with auto wipers (turned mine off with IOD tool as crap) just happy auto lights is back to normal
Post #421260 5th Jan 2017 3:34pm
Glad to hear you resolved it Thumbs Up
Post #421298 5th Jan 2017 6:39pm
Mine are excellent, barely have to interfere at all, maybe your auto wiper sensor is faulty as well...!!!
Glad the lights are fixed Thumbs Up Pete
Post #421303 5th Jan 2017 6:51pm
A1GSS
So was it more or less what I suggested ^^^ ... not fitted to the screen properly...? Graham
____
Post #421354 5th Jan 2017 11:42pm
Robgosty
Not really as auto lights were on all the time with lens in place, now it's removed and sensor fitted direct to screen lights work fine, as I said can presume the purple lens is just to do with autowipers which I have turned off
Post #421392 6th Jan 2017 11:55am
p38arover
Australia
I posted some pics in a couple of other threads but I can't link the post as I can't quote it. See http://www.fullfatrr.com/forum/topic36415-60.html
Note how the hole in the screen mask doesn't line up with the red circular window in the sensor. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #434101 7th Apr 2017 4:12am
