![]() | Home > Technical (L322) > Removing ball joint - at wits end |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
I haven't done this job on the FF myself so I'm trying to figure out what is the problem. Based off your last photo I'm guessing that its the bolt at the bottom of the ball joint that you ultimately want off? Along with the rest off the joint?
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 ![]() ![]() ![]() |
Blimey that's not a cheaply!!
GDM Member Since: 21 Nov 2016 Location: West Sussex Posts: 165 ![]() ![]() ![]() |
On top of what Andy says, also get a thin wide bladed chisel behind the other 'ear' on the inside of the hub. Mine were pretty well seized when I changed them but having spent an hour finding the right technique on the first one, I had the second out in about 5 minutes. |
Thanks again! Yeah I guess I can take the other arm off the hub to get a bit more room, I think the other side of the other ear is harder to get to isn't it? You would need the brake disc off to do that and I can't get mine off ![]() It's so hard to hit under there with limited room on my axle stands, I ideally need a better jack and axle stands if I am to undertake any more tasks on the RR! A mate of mine who used to work for Land Rover then an Indy said the best way to remove it was an air chisel, now I can pick one up from Screwfix for £25 and hopefully borrow a mates compressor, surely to god if I got that in the ear that's opening it would pull the joint through?! ![]() |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
Mine was a combination of hitting from above and chiselling from below, The key is making the hits count, if it feels hollow when you are hitting it from the top then you are losing the impact needed to shock it out and yes i could mainly get to one of the ears only so hitting from above is going to have to be the way forward.
Sounds like the plan for Sunday!!
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 ![]() ![]() ![]() |
can you use a 1/2" socket extension to give you more clearance above the driveshaft for the hammer to hit onto ?? Regards
Does turning the wheel give you more room to get in there ?
Get a large drift, or a stout masonry chisel, then with the steering on full lock you can get down past the CV joint and hit the drift/chisel from above. Try using a club hammer. If I was closer, I would give you a hand. |
No it wasn't but I'd had the opportunity to try it out at a garage in Kendal when a wheel bearing went in the 110. The batteries aren't cheap so you're buying into that as well but they're usuable by all their M18 tools. But it's rated up to 1600Nm to undo stuff. I find it hilarious the "low torque" setting is over 100Nm... The two top brands for this kind of stuff seem to be Milwaukee and Snap On buy you pay for what you get.
Going to try again tomorrow, I've got a mate who's got a PSV pit bay so can jack it up on there and get a better swing with the hammer plus heat!
Pluck up, it could be busier. I had 12 pups born on Christmas Eve. On top of that had to demolish the brickwork under the stairs to give her somewhere to look after them. Also been basically overhauling most bushes and ball joints on the 110 to get it through its MoT. And replaced a section of fence in the garden that was collapsing. On top of that a new boiler will need to be installed in the coming weeks.
oh jesus that sounds like a hectic one!!
Good luck, remember to support the hub underneath so you are hitting something solid
