![]() | Home > In Car Electronics (L322) > How to... Fit Android Head Unit to 2002-2005... |
builder1966 Member Since: 23 Aug 2016 Location: ashingdon Posts: 299 ![]() ![]() ![]() |
the main reason for needing 4g is all the pads I have for grandkids are 4g and they are always in all the cars so I have a mifi 4g unit in all my cars 3g is rubbish around here as well 4g is as fast if not faster than broadband |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8546 ![]() ![]() ![]() |
khyber Member Since: 21 Mar 2017 Location: new york Posts: 30 ![]() ![]() ![]() |
This is a brilliant thread. I am embarking on upgrading mine with Eonon GA6201 unit that is available on eBay. I also need the extension cable. One question I have is regarding the need to replace the factory amp as mentioned in this thread. Why is that necessary? My setup doesn't include the TV tuner, only Navi, Radio tuner and amp in the boot/trunk. It looks like I have to connect the Eonon extension cable to the two connectors that are currently attached to the Radio tuner. The connectors on the Eonon extension and the ones attached to radio tunner seem to match. |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Because you have the additional amp in the boot, you have DSP fitted to the car, this means that you'll have to follow Pete's wiring diagram for the speakers, can be a bit fiddly as you're connecting up to 4 wires at a time, just follow Pete's chart and you wont go wrong.
Thanks for your reply. I understand that I probably don't need the amplifier but I want to avoid cutting wires or rewiring if I can.
It is possible that it will work as plug and play, but this would be the first aftermarket system to work with the DSP. The dsp gets a signal on the ibus from the BM54 unit to turn it on, Eonon might have sorted out the code to fix the system...but they would be the first to do this. on the up side if it doesn't work you'll have already got the lead from the new stereo to the place that it needs to be to connect to the speaker wires from the dsp. For the cost involved I'd still extend the subwoofer phono to the rear just incase, and if you haven't already got one a feed for a reversing camera is a must! FYI before you put everything back a lead going the other way from the reverse lights to the head unit would be a good idea |
I have already ordered a backup camera and will install at the same time. It's the one that fits in place of the license plate lights.
You need to run a feed from the reversing lights to the head unit so that it knows when you're going backwards, at the same time you need to run video from the camera to the head unit.. and you'll need an extra lead as there is no way that 6 meters is going to be enough to get from the tailgate to the dash, without going through the roof lining, although that's not such a bad idea... might be enough, if it is then use the red wire to power the camera and run an extra lead from the head to the reverse lamps... you could try and pick up the feed from the gearbox end, but it's tight... much easier to lift the floor in the back and the wires for the reverse lamps are just to the right of centre, there is a multi plug there |
Thank you for this bit of info that I totally get now. Your are right the 5M video wire included with backup camera won't be enough. I need an extra extension at least from tailgate camera to the boot where Amp and Navi unit are located so I can run all the extension wires from there to the front of the car.
Ottar Member Since: 07 Jun 2016 Location: Bekkestua Posts: 8 ![]() ![]() ![]() |
Very good tip on the sub lead and camera feed.
Khyber.
One like this http://www.ebay.co.uk/itm/Waterproof-170-N...SwmtJXX8wp Yesterday I couldn't spell Engineer... Today I are one!
Yes, it looks similar. I ordered from Amazon US. |
I checked my boot today and noticed that I have a logic 7 set up (BM54, Logic 7 processor, Amp and Navi units). A quick search revealed that this is not DSP but couldn't find much info on if it would work with these after market units. I was led to believe by everyone that I have a DSP system so this is a shocker. I should have noticed the Logic 7 emblems on my speaker covers. Need to do additional research but let me know if you know anything about this setup. And my Eonon unit also arrived today but the extension cable will take a few more days. |
