Home > Technical (L322) > Speed Limiter......is there one? |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1348 |
My Westie has cruise control (normal not adaptive ) but there doesn't seem to be a speed limit function, unless I'm missing something. Can't find it in the manual either. Seems a big omission for such an upmarket car. Even my 11yr old Citroen has it 2017 4.4 SDV8 Autobiography
27th Dec 2016 3:32pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35108 |
you can set a speed limit notification on the dash, is that any good. ... - .- -.
27th Dec 2016 3:35pm |
That might be useful Stan but I was hoping for a system which would stop me accelerating beyond the speed I set. I find it useful in those awful average speed limit zones which seem to be cropping up everywhere at the moment 2017 4.4 SDV8 Autobiography
27th Dec 2016 3:44pm |
something stopping you from physically accelerating could prove risky Rob... you might need to accelerate out of a dangerous situation.. ... - .- -.
27th Dec 2016 3:51pm |
That's true but on my Citroen the accelerator has a switch, I guess something like the kickdown switch on the Westie, which overrides the limit and allows you to accelerate. If it's not a facility on the L322 then I just need to be more careful in average speed zones 2017 4.4 SDV8 Autobiography
27th Dec 2016 3:59pm |
or set the limit on the cruise? ... - .- -.
27th Dec 2016 4:01pm |
You can Stan. On my L405 if you hit the kickdown switch it cancels the limiter |
27th Dec 2016 8:11pm |
thanks for the info Dom ... - .- -.
27th Dec 2016 8:16pm |
Guess it was introduced with the L405, as not on the L322. 2017 4.4 SDV8 Autobiography 2012 4.4 TDV8 Westminster - Gone, but not forgotten |
28th Dec 2016 12:25am |
Yep, neither of my L322 Supercharged AB cars had the limiter. You get an extra switch down by the TR knob on L405 which flips it between a limiter and cruise.
28th Dec 2016 10:26am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3964 |
I think the only speed limiter on an L322 is when in true LR fashion the wheels fall off.
28th Dec 2016 11:56am |
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 |
You could always route a piece of string down your trouser leg, one end tied to the accelerator and the other to your gentleman's sausage. Just don't forget to disengage before alighting the vehicle. And don't disengage outside a school |
28th Dec 2016 12:21pm |
It does seem strange that every other car I've had with cruise control (and all costing a fraction of an FF) have all had a speed limiter as part of the cruise control. It's really only a software programming issue. 2017 4.4 SDV8 Autobiography
28th Dec 2016 4:10pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1366 |
I have a Road Angel Gem which displays the car's average speed over the stretch covered by the cameras, the car's current speed (generally the speedo reads a bit more) and the limit. It is a bit noisy to use all the time on roads I know well, but is useful on (say) the A9 which has one average speed section after another and on unfamiliar roads. What a lot of cameras there are in motorway gantries these days, not visible on approach. Only Range Rovers since 1988 |
28th Dec 2016 9:37pm |
