Home > Technical (L322) > Speed Limiter......is there one?
Rob99
My Westie has cruise control (normal not adaptive Sad ) but there doesn't seem to be a speed limit function, unless I'm missing something. Can't find it in the manual either. Seems a big omission for such an upmarket car. Even my 11yr old Citroen has it Shocked 2017 4.4 SDV8 Autobiography
2012 4.4 TDV8 Westminster - Gone, but not forgotten
Post #419731 27th Dec 2016 2:32pm
you can set a speed limit notification on the dash, is that any good. ... - .- -.
Post #419734 27th Dec 2016 2:35pm
Rob99
That might be useful Stan but I was hoping for a system which would stop me accelerating beyond the speed I set. I find it useful in those awful average speed limit zones which seem to be cropping up everywhere at the moment Evil or Very Mad 2017 4.4 SDV8 Autobiography
Post #419737 27th Dec 2016 2:44pm
something stopping you from physically accelerating could prove risky Rob... you might need to accelerate out of a dangerous situation.. ... - .- -.
Post #419738 27th Dec 2016 2:51pm
Rob99
That's true but on my Citroen the accelerator has a switch, I guess something like the kickdown switch on the Westie, which overrides the limit and allows you to accelerate. If it's not a facility on the L322 then I just need to be more careful in average speed zones Shocked 2017 4.4 SDV8 Autobiography
Post #419739 27th Dec 2016 2:59pm
or set the limit on the cruise? ... - .- -.
Post #419740 27th Dec 2016 3:01pm
mzplcg
You can Stan. On my L405 if you hit the kickdown switch it cancels the limiter Thumbs Up
Post #419779 27th Dec 2016 7:11pm
thanks for the info Dom Thumbs Up ... - .- -.
Post #419781 27th Dec 2016 7:16pm
Funny how we prefer different things - in average speed camera zones, I use the cruise & have never even tried the limiter
Good to know how it works though Thumbs Up
Post #419784 27th Dec 2016 7:31pm
Rob99
Guess it was introduced with the L405, as not on the L322. 2017 4.4 SDV8 Autobiography
Post #419806 27th Dec 2016 11:25pm
mzplcg
Yep, neither of my L322 Supercharged AB cars had the limiter. You get an extra switch down by the TR knob on L405 which flips it between a limiter and cruise.
But the limiter on L405 doesn't work as well as the Mercedes version. If you go into over-run down a hill it changes down to give engine braking but won't actually apply the brakes, which is a bit daft seeing as the cruise version (adaptive) will apply the brakes if you get too close to the car in front. Mine even has the follow mode for traffic so the car almost drives itself so the lack of braking on over-run does seem to be a strange thing to leave out.
Post #419825 28th Dec 2016 9:26am
I think the only speed limiter on an L322 is when in true LR fashion the wheels fall off. Thumbs Up
I've always thought that as well as normal cruise control it would be helpful to be able to set a predetermined speed ie 30, 40, 50, 60 and 70mph by the press of a button.
Post #419831 28th Dec 2016 10:56am
Giantlandyman
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
You could always route a piece of string down your trouser leg, one end tied to the accelerator and the other to your gentleman's sausage. Just don't forget to disengage before alighting the vehicle. And don't disengage outside a school Twisted Evil
Post #419832 28th Dec 2016 11:21am
Rob99
It does seem strange that every other car I've had with cruise control (and all costing a fraction of an FF) have all had a speed limiter as part of the cruise control. It's really only a software programming issue. 2017 4.4 SDV8 Autobiography
Post #419852 28th Dec 2016 3:10pm
CS
I have a Road Angel Gem which displays the car's average speed over the stretch covered by the cameras, the car's current speed (generally the speedo reads a bit more) and the limit. It is a bit noisy to use all the time on roads I know well, but is useful on (say) the A9 which has one average speed section after another and on unfamiliar roads. What a lot of cameras there are in motorway gantries these days, not visible on approach. Only Range Rovers since 1988
Post #419904 28th Dec 2016 8:37pm
