Home > Technical (L322) > "Restricted Performance" error message |
Walshy Member Since: 18 Dec 2016 Location: Nottingham Posts: 8 |
Thanks.
26th Dec 2016 5:38pm |
Range Rover LSE Member Since: 15 Jul 2012 Location: Preston Posts: 46 |
I had a 2010 3.6 TDV8 it displayed exactly the same symptoms, however mine occurred when working hard under load with a caravan on the back. Turned out to be the inlet hoses, one of which had developed a very small tear underneath which was difficult to see but opened up and caused the symptoms under load. Range Rover Sport 2023 D350 Autobiography
26th Dec 2016 11:57pm |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 |
^ Was it a tiny tear on one of the top hoses? |
28th Dec 2016 9:24pm |
Yes, the tear was underneath and so small the LR customer service guy that attended me didn't spot but the experienced tech at the dealers went to it straight away given the faults reported. The dealers thought it could have been there a while as it didn't show up under normal conditions and only showed when climbing steep hills with the van on the back on the motorway. However the catalogue of faults read like the original post and caused the car to go into reduced performance mode. The dealers fixed it and replaced both hoses as a precaution, I then put the van on the back and did the same journey without any further incidents the following day. Range Rover Sport 2023 D350 Autobiography
29th Dec 2016 6:20am |
Thanks very much.
29th Dec 2016 10:55am |
Eventually fixed, well I hope so anyway, needs a long run to test it out.
4th Jan 2017 8:56pm |
steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208 |
The following diagram should help. Basically, you've replaced the top two - highlighted yellow (which are the ones that seem to commonly fail). The others are to the bottom of the intercooler and I guess are much harder to get at. They were on the TD6, anyway.
4th Jan 2017 9:32pm |
Thanks steveball don't think I'll be replacing them will have to get my mechanic to do those. L322 TDV8 Vogue SE Java Black |
4th Jan 2017 10:05pm |
KRV24 Member Since: 02 May 2016 Location: Berkshire Posts: 35 |
Got the dreaded Bong and exactly the same error messages as you Walshy. Restricted performance, Active Stability Control Not Available etc. Even the confirm ride height message after a restart. Have checked the wires on the struts but all good there so hopeing its just a split hose. Couldn't see anything visibily obvious so have booked in with the local Independant who will put it on the diagnostics machine. Times like this i wish i had an IID tool! Although not sure if a cracked inlet hose will show up as an error?
30th Mar 2017 5:45pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8661 |
take the passenger side one off, and check it under the webbing to see if its split - the link to the how to is on the previous page, it takes 5 mins and required no spanner skills.
30th Mar 2017 5:57pm |
Cheers northernmonkeyjones
30th Mar 2017 7:57pm |
Very interested in the outcome.........
31st Mar 2017 8:06pm |
Would if it's under load I would suspect hoses somewhere.
31st Mar 2017 8:08pm |
Might get someone to check all of them before my annual trip to Cornwall.
31st Mar 2017 8:22pm |
