Home > Technical (L322) > "Restricted Performance" error message |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8515 |
Sounds like it could be the adaptive dynamics cable running to the top of the struts, wears through and can cause suspension issues. Not sure if it would cause the restrictive performance issues though. Might be worth checking the turbo pipes in case one has burst (more common in the 3.6 though) but not unheard of in the 4.4.
23rd Aug 2015 6:20pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7926 |
Any black smoke ?
23rd Aug 2015 6:29pm |
Did get a bit of smoke with mine on the 3.6 too, but not masses. The top turbo hose on my 4.4 had a bad seal on it and was blowing past the seal on the the throttle body end. New hose for £70 seems to have sorted it, no loss in performance or errOrs though. There is nothing that can't be fixed with a hammer😜😜
23rd Aug 2015 6:36pm |
Old Skool Member Since: 23 Aug 2015 Location: London Posts: 23 |
Thanks guys. Just to clarify although it's a 2010MY the car is actually a 3.6TDV8 so maybe it is the turbo hose. To be honest I haven't noticed a plume of smoke. Main dealer or independent to fix this - any views? To date it's only ever seen a main dealer but as I said I've never seen one in London and my experience to date has not been great |
23rd Aug 2015 6:42pm |
Ah, was looking at the avatar,
23rd Aug 2015 6:50pm |
3.6 then it's most likely a hose they are notorious for splitting - cheap fix |
23rd Aug 2015 6:55pm |
Possibly 2 separate faults though as the suspension fault sounds separate to the reduced performance to me. If the cables on the strut have frayed through the it's possible a dealer may do it under a service bulletin, I would check it first, the damage will be obvious once the black cap is removed (if that is the cause) then call the dealer and try and get LR to pay for it as its a known problem. Worth a shot. There is nothing that can't be fixed with a hammer😜😜
23rd Aug 2015 7:07pm |
Thanks so much guys.
1st Sep 2015 10:57pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Have them change both hoses otherwise the other side will follow suit shortly sir |
2nd Sep 2015 12:41am |
^^ Top advice - they are only something like £30 each so definitely worth doing both if it's going in for the work to be done. |
2nd Sep 2015 6:49am |
+ don't let them bill you for more than 1/2 hour labour max! Really should only take 10 mins...... There is nothing that can't be fixed with a hammer😜😜
3rd Sep 2015 12:03pm |
Walshy Member Since: 18 Dec 2016 Location: Nottingham Posts: 8 |
Anyone know if you can buy a silicone replacement kit for the turbo? Mines got a nice split in it! |
26th Dec 2016 5:04pm |
yes they are available and several folks have fitted them.
26th Dec 2016 5:08pm |
Thanks northernmonkeyjones
26th Dec 2016 5:10pm |
