Home > Technical (L322) > "Restricted Performance" error message
Page 1 of 3 123>
Old Skool
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
Hi all.
First time poster so please be gentle and apologies if this is in the wrong section...
I have a FFRR 2010 and have recently been getting multiple error messages which first say "Warning Restricted Performance" and then "Active Stability Control Not Available" and then a number of other error messages in a cycle. I then have very strange and pretty non-existent throttle response.
This is becoming more frequent and tends to happen when I am doing anywhere above 40/50 miles an hour and go for some acceleration (for example to overtake). As you can imagine this is pretty disconcerting as it usually therefore happens on dual carriageways and main thoroughfares. The only way I've found to deal with it is to pull over and restart the car. When I do so it asks me to "reconfirm ride height" and then operates entirely normally.
This has started to become more frequent so I was wondering whether anyone else had this problem and could shed any light?
A brief Internet search suggests anything from a bad battery to a bad cable in the front left side (can't recall which cable now!) it is pretty noticeable however that it only seems to happen under hard acceleration and when the car is already doing say 40/50.
On a similar note, can anyone recommend a good independent in central London or greater London? I normally get my car looked at by Guy Salmon Sheffield where my parents are but don't particularly want to undertake a 160 mile motorway journey with this sort of issue....
Any help or guidance massively appreciated!
Post #343955 23rd Aug 2015 4:39pm
Sounds like it could be the adaptive dynamics cable running to the top of the struts, wears through and can cause suspension issues. Not sure if it would cause the restrictive performance issues though. Might be worth checking the turbo pipes in case one has burst (more common in the 3.6 though) but not unheard of in the 4.4.
Both can be checked with minimal tools, so worth having a go to try to identify
Look at this re the adaptive dynamics fault:
http://www.fullfatrr.com/forum/topic22949....mics+fault
The symptoms are as you describe if a turbo hose has gone, foot down = bong, on the 3.6 it comes up as engine system fault, with no throttle response and a restart sorts it for a few miles. There is nothing that can't be fixed with a hammer😜😜
Post #343981 23rd Aug 2015 6:20pm
Any black smoke ?
The turbo hoses usually result in a nice little cloud being left in your wake.
Post #343983 23rd Aug 2015 6:29pm
Did get a bit of smoke with mine on the 3.6 too, but not masses. The top turbo hose on my 4.4 had a bad seal on it and was blowing past the seal on the the throttle body end. New hose for £70 seems to have sorted it, no loss in performance or errOrs though. There is nothing that can't be fixed with a hammer😜😜
Post #343989 23rd Aug 2015 6:36pm
Old Skool
Thanks guys. Just to clarify although it's a 2010MY the car is actually a 3.6TDV8 so maybe it is the turbo hose. To be honest I haven't noticed a plume of smoke. Main dealer or independent to fix this - any views? To date it's only ever seen a main dealer but as I said I've never seen one in London and my experience to date has not been great
Post #343991 23rd Aug 2015 6:42pm
Ah, was looking at the avatar,
Have a look at this in the wiki
http://www.fullfatrr.com/forum/topic26843.html
Get s screwdriver out and check, it takes 5 mins and can be done by anyone who can change a plug! There is nothing that can't be fixed with a hammer😜😜
Post #343993 23rd Aug 2015 6:50pm
3.6 then it's most likely a hose they are notorious for splitting - cheap fix Thumbs Up
Post #343995 23rd Aug 2015 6:55pm
Possibly 2 separate faults though as the suspension fault sounds separate to the reduced performance to me. If the cables on the strut have frayed through the it's possible a dealer may do it under a service bulletin, I would check it first, the damage will be obvious once the black cap is removed (if that is the cause) then call the dealer and try and get LR to pay for it as its a known problem. Worth a shot. There is nothing that can't be fixed with a hammer😜😜
Post #343999 23rd Aug 2015 7:07pm
Old Skool
Thanks so much guys.
Took a look in the engine bay and yes indeed, the right hand side hose had a great big crack in it. Tried to repair it with electrical tape, amalgamating tape and aluminium reflective tape which has helped somewhat, but a few long journeys have resulted in the tape melting away and a noticeable lack of power returning.
Car has been booked in for a repair job so I'm hoping it is only this which was the issue.
Thanks again - my first post here and the swift responses were precisely on point. Great resource!
Post #345583 1st Sep 2015 10:57pm
Have them change both hoses otherwise the other side will follow suit shortly sir Thumbs Up
Post #345588 2nd Sep 2015 12:41am
^^ Top advice - they are only something like £30 each so definitely worth doing both if it's going in for the work to be done.
Post #345593 2nd Sep 2015 6:49am
+ don't let them bill you for more than 1/2 hour labour max! Really should only take 10 mins...... There is nothing that can't be fixed with a hammer😜😜
Post #345835 3rd Sep 2015 12:03pm
Walshy
United Kingdom 2010 Range Rover Vogue SE TDV8 Java Black
Anyone know if you can buy a silicone replacement kit for the turbo? Mines got a nice split in it!
Post #419639 26th Dec 2016 5:04pm
yes they are available and several folks have fitted them. Thumbs Up
have a look here http://www.lhss.co.uk/land-rover-hoses/turbo-hoses/ There is nothing that can't be fixed with a hammer😜😜
Post #419641 26th Dec 2016 5:08pm
Walshy
Thanks northernmonkeyjones
Can you not buy online on that website?
Guessing these are the same though?
http://www.island-4x4.co.uk/silicone-hose-...34045.html
Post #419643 26th Dec 2016 5:10pm
Page 1 of 3 123>
