Home > Technical (L322) > P0705 transmission code |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8192 |
Can't help with the code, could be the result of the low battery... If it doesn't return forget about it....
30th Jun 2016 10:15pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 963 |
Although that error code is not uncommon on pre-’06 petrol models which have an externally mounted inhibitor switch, it’s much less common on the 6-speed transmission as the switch is internal
1st Jul 2016 8:51am |
craig nicholas Member Since: 08 May 2016 Location: Lancashire Posts: 32 |
Thanks Phil. As said , I've erased the code and I need to take it out on a longer journey , the RR is my weekend toy and doesn't get used much.
1st Jul 2016 8:55am |
That's fine, no problem at all, glad to help.... Pete
1st Jul 2016 11:16am |
Sorry Pete, My mistake as I thought I'd already replied a thanks also to your good self .
1st Jul 2016 12:31pm |
evening all and a very merry christmas.
25th Dec 2016 10:45pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1753 |
A seized gear selector can cause this issue. Is the lever nice and free to move back and forward, or does it feel stiff/notchy at all? |
25th Dec 2016 10:48pm |
no, gear selector is smooth. ive tried the HDC switch that works ive also used the low/high range switch and i can hear the low box engage and drive in low box . all seems to work as one would expect |
25th Dec 2016 10:56pm |
Trying to work out when i started getting this p0705 transmission failsafe . could changing the gearbox oil and filter ? not long after purchasing this car i spotted a oil leak from the gearbox electrical connector sleeve. its possible that this p0705 error may have started after this oil change.
27th Dec 2016 3:49pm |
builder1966 Member Since: 23 Aug 2016 Location: ashingdon Posts: 299 |
surly just take phils advise get booked in and sorted its a range rover we don't own em to skint on em just spend the money everythings sorted with money good luck |
27th Dec 2016 3:55pm |
Get booked in where? |
27th Dec 2016 4:45pm |
gearbox garage or dealers |
27th Dec 2016 6:38pm |
P0705 issues are relatively common on the 5-speed ZF units as the inhibitor switch is mounted externally (i.e. vulnerable to the elements) and the L1 to L4 logic function is achieved using sprung fingers mounted on a wiper sliding across contacts.
28th Dec 2016 12:31am |
Phil, thanks for the pointers. my intention today (28/12/16) is to get under the rangie and check oil level,any wire connectors i may have disturb on the original gearbox service and the cable you have indicated above.
28th Dec 2016 9:57am |
