Home > Technical (L322) > P0705 transmission code
craig nicholas
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Evening gents and ladies .
Out today in my 2006 (56) sc ffrr . Not my daily car. I decided to drive the car in sport mode to help charge the battery (raised rpm) as the car has been stood for most the week,not hammering the car.
I got a notification and the car went into limp mode.
I got home and used a code reader to investigate. Below is what I got. I have cleared the code and drove the car around the block without any issue. I've Googled the code and I'm a little unsure of the possibilities.
Would be grateful for some not to technical advise .
Post #393926 30th Jun 2016 9:35pm
Can't help with the code, could be the result of the low battery... If it doesn't return forget about it....
But
No need to raise revs to charge the battery, modern cars will be at full charge rate at just off tickover.... Thumbs Up Pete
Post #393951 30th Jun 2016 11:15pm
RRPhil
Although that error code is not uncommon on pre-’06 petrol models which have an externally mounted inhibitor switch, it’s much less common on the 6-speed transmission as the switch is internal
Hopefully it’s just your battery charging level that’s causing the issue and it won’t reoccur. Otherwise you may need to remove the Mechatronic unit and clean the switch contacts.
Phil
Post #393976 1st Jul 2016 9:51am
craig nicholas
Thanks Phil. As said , I've erased the code and I need to take it out on a longer journey , the RR is my weekend toy and doesn't get used much.
I will update later.
Post #393979 1st Jul 2016 9:55am
That's fine, no problem at all, glad to help.... Rolling Eyes Pete
Post #393995 1st Jul 2016 12:16pm
craig nicholas
Sorry Pete, My mistake as I thought I'd already replied a thanks also to your good self .
Thanks Pete.
Post #394006 1st Jul 2016 1:31pm
craig nicholas
p0705
evening all and a very merry christmas.
so far i encounter this trans failsafe code above at least once a month in any driving mode and at any speed, ive also once had this happen whilst stood still waiting at traffic lights . on this occasion i was sat at the traffic lights and the rangie felt like it lowered slightly and pinged and ponged and went into limp mode. same code as above came up. I cant say if the rangie drops in height whilst on the move as trans failsafe comes on nor can i make it happen on request.
in the time ive been trying various fixes, ive replaced the gearbox oil and filter,new battery and had the alternator checked .
my failing is i know nothing of electrics , i need help.!.
Post #419580 25th Dec 2016 11:45pm
Mikey
A seized gear selector can cause this issue. Is the lever nice and free to move back and forward, or does it feel stiff/notchy at all?
Post #419582 25th Dec 2016 11:48pm
craig nicholas
p0705
no, gear selector is smooth. ive tried the HDC switch that works ive also used the low/high range switch and i can hear the low box engage and drive in low box . all seems to work as one would expect
Post #419583 25th Dec 2016 11:56pm
craig nicholas
p0705
Trying to work out when i started getting this p0705 transmission failsafe . could changing the gearbox oil and filter ? not long after purchasing this car i spotted a oil leak from the gearbox electrical connector sleeve. its possible that this p0705 error may have started after this oil change.
i will check the oil level first, Do you think it would be wise to do another oil and filter change?
the parts i used on the first gearbox are i the link.
http://www.lrparts.net/automatic-transmiss...ne-zf.html
do i order the same again?
Post #419748 27th Dec 2016 4:49pm
builder1966
England 2004 Range Rover Vogue Td6 Adriatic Blue
surly just take phils advise get booked in and sorted its a range rover we don't own em to skint on em just spend the money everythings sorted with money good luck
Post #419751 27th Dec 2016 4:55pm
craig nicholas
Get booked in where?
Post #419757 27th Dec 2016 5:45pm
builder1966
gearbox garage or dealers
Post #419773 27th Dec 2016 7:38pm
RRPhil
P0705 issues are relatively common on the 5-speed ZF units as the inhibitor switch is mounted externally (i.e. vulnerable to the elements) and the L1 to L4 logic function is achieved using sprung fingers mounted on a wiper sliding across contacts.
For the 6-speed unit ZF moved away from an external switch with contacts and instead integrated the position switch into the electronic control module which also contains the transmission control unit (ECU) which is coded to the vehicle.
Unlike for the 5-speed, therefore, it’s not simply a question of sourcing a replacement switch. For the 6-speed the complete Mechatronic unit would have to be replaced and then re-coded to the vehicle.
The 6-speed position switch appears to be a ‘Hall effect’ type where you can see, in the photos, what appears to be 4 strips of magnets in the sliding part (attached to the transmission’s manual valve and guided by the rooster comb) which generates the L1 to L4 logic in the fixed part without any physical contact.
It seems hard to imagine therefore what could have gone wrong with this sealed and non-contacting arrangement in your particular case, but I would suggest that it’s worth at least taking the slider out and cleaning it?
One other thing I did think about, though – as it’s a well-known issue with the 6HP26 - is that the cable trunnion (which clamps the selector cable to the selector lever at the transmission end) corrodes and seizes in its hole, preventing the trunnion from articulating as the lever moves through its arc.
Potentially I guess this could mean that the lever might rotate to a position beyond which it was designed to go and the slider may therefore register a linear position outside of its normal range? Anyway, this may certainly be an initial place to look as it wouldn’t cost anything to fix.
Phil
Post #419815 28th Dec 2016 1:31am
craig nicholas
p0705
Phil, thanks for the pointers. my intention today (28/12/16) is to get under the rangie and check oil level,any wire connectors i may have disturb on the original gearbox service and the cable you have indicated above.
after that , i will be seeking outside help.
again Phil, thanks for taking the time to explain at a depth you have about the internal workings, i dont think i would want to takle removing the slider plate as you suggested, this i think is outside my knowledge. i will be leaving that to a professional.
thanks, Craig.
Post #419829 28th Dec 2016 10:57am
