![]() | Home > Maintenance & Mods (L322) > Final Stage Blower Resistor Replacement |
Stormin Member Since: 22 Feb 2012 Location: West Yorkshire Posts: 266 ![]() ![]() |
Just replaced mine, but the new one is a plastic casing with small metal pins and the old one is all metal with huge pins.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35474 ![]() ![]() |
yes they have improved the unit...... ... - .- -.
Thanks Stan
Sharky1168 Member Since: 21 Jul 2015 Location: Rochdale Posts: 23 ![]() ![]() ![]() |
Many thanks to all contributors, with your help....and quite a few old fashioned Anglo Saxon words & raw skin on my wrist....finally replaced my FSR today, with much appreciated success! Again a great wiki Current RR L322 TDV8 VOGUE
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 730 ![]() ![]() ![]() |
Hi Ian Have you ever had to replace the rear FSR? My TD6 is on her 3rd FSR (front) in 7 years, damn things. Someone mentioned the rear one too but no one seemed to know much about it |
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 605 ![]() ![]() ![]() |
mine is playing up but not bothering me at the mo. shall i leave it until it stops ? does not do it all the time............ |
bwelton Member Since: 26 May 2014 Location: Milton Keynes Posts: 137 ![]() ![]() ![]() |
I’ve had many problems with FSR and intermittent operation of the blower. After two years of swapping FSR’s checking motors and duct servo units, I finally found that the problem was actually the connector to the FSR.
It’s been 6 months since my last post where I had replaced the FSR plug and tail of the connecting harness. The blower and heating controls had all then been ok for 6 months until two weeks ago and the blower stopped working (now that it’s been icy !!)
322BLL Member Since: 18 Apr 2019 Location: Estonia Posts: 73 ![]() ![]() |
If I am not mistaking now, did't this happen when you pull the blower relay out or was it the fsr plug?
Currently with the FSR in, the bower is on Full, even when the car is locked i.e. battery drain...
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 372 ![]() ![]() ![]() |
When my FSR failed the blower was on full speed all the time even with ignition off and car locked. New FSR cured mine so good luck 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Just inserted the new FSR and the Blower is no longer on Full all the time. Blower control apears to have reverted to normal ![]() I'll see how it gets on in the following weeks. ------------------------------------- MY 2012 4.4 TDV8 |
I’ve found with the new FSR from Amazon, it only increments the Blower speed on the first 3 increments of the Blower Speed.
Arbuckle Member Since: 11 Nov 2018 Location: Northants Posts: 78 ![]() ![]() ![]() |
Just some thoughts.
