Home > Maintenance & Mods (L322) > Final Stage Blower Resistor Replacement
Page 3 of 4 <1234>
109er
Germany 2009 Range Rover Vogue TDV8 Bournville
The little critter is on the right hand side, which is the passenger side where I live. Don´t know if they put it somewhere else on RHD cars though.
Post #295886 29th Nov 2014 1:48pm
Stormin
2003 Range Rover HSE Td6 Epsom Green
Just replaced mine, but the new one is a plastic casing with small metal pins and the old one is all metal with huge pins.
Is that right Three things in a blokes life his dog,his car and a Cornish pasty,nothing else matters.
2010 Range Rover Vogue SE Santorini Black, Arabica Aniline seats
Previous cars
1973 Mini 1000
1971 Hillman Avenger
1975 Chrysler Sunbeam
1981 Ford Cortina
1985 Volvo 340
1989 VW Golf
1989 Volvo 240
1991 Volvo 240
1991 Jaguar Soveriegn
1996 BMW 730
2003 Honda CRV
1999 Jaguar Soveriegn
2003 Range Rover HSE Epson Green with Sand trim.
Post #317843 13th Mar 2015 12:27pm
yes they have improved the unit...... ... - .- -.
Post #317845 13th Mar 2015 12:31pm
Stormin
Thanks Stan
Would hate to have to take it out again Three things in a blokes life his dog,his car and a Cornish pasty,nothing else matters.
Previous cars
1973 Mini 1000
1981 Ford Cortina
1985 Volvo 340
1989 VW Golf
1989 Volvo 240
1991 Volvo 240
1996 BMW 730
2003 Honda CRV
Post #317854 13th Mar 2015 12:47pm
Sharky1168
Appreciate the wiki
Many thanks to all contributors, with your help....and quite a few old fashioned Anglo Saxon words & raw skin on my wrist....finally replaced my FSR today, with much appreciated success! Again a great wiki Current RR L322 TDV8 VOGUE
Past: RR L322 TD6 HSE, Discovery 2. Land Cruiser V8, Saab 9-7x, Nissan Maxima, Ford Granada I, II, III
Post #413419 13th Nov 2016 7:23pm
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
IanV8 wrote:
Ł20.67 for mine from LR in Kings Lynn.
There are two types one for the rear and one for the front they are not interchangeable as I found out.
Ian
Hi Ian
Have you ever had to replace the rear FSR? My TD6 is on her 3rd FSR (front) in 7 years, damn things. Someone mentioned the rear one too but no one seemed to know much about it
Post #419467 24th Dec 2016 3:17pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
mine is playing up but not bothering me at the mo. shall i leave it until it stops ? does not do it all the time............
Post #419476 24th Dec 2016 4:35pm
bwelton
United Kingdom 2012 Range Rover Vogue SE TDV8 Zermatt Silver
I’ve had many problems with FSR and intermittent operation of the blower. After two years of swapping FSR’s checking motors and duct servo units, I finally found that the problem was actually the connector to the FSR.
I purchased a replacement connector off eBay that is sold for BMW”s, cut off the old and soldered in the new. In doing so, I extended the loom by approx 15cm, so made it much easier to refit the FSR connector as it was less tight to navigate the hand under the steering column / centre console.
https://www.ebay.co.uk/itm/152702262852
If you have tried everything else, consider this.
After fitting it, I needed to do the Battery disconnect / reset, to get to a clean state of the car, but now it all seems to be working perfectly (fingers crossed).
MY 2012 4.4 TDV8
Post #564930 18th Aug 2020 5:54pm
bwelton
It’s been 6 months since my last post where I had replaced the FSR plug and tail of the connecting harness. The blower and heating controls had all then been ok for 6 months until two weeks ago and the blower stopped working (now that it’s been icy !!)
Then tonight, I’m driving along and the Blower starts. I thought great, a warm car again !!
However, I found the blower is on full even irrespective of the blower setting and even when the engine is switched off and car locked !!! I should be an expert on FSR and Blower problems by now, but have not seen this Full Speed Blower problem.
I did have a spare FSR and so I swapped it over but, it still has the same problem (full speed), irrespective of blower setting.
I’ve removed the FSR now to stop the battery draining over night but now need to make a new plan.
Any suggestions ? Should I replace the FSR or could it be something else ?
Thx -------------------------------------
MY 2012 4.4 TDV8
Post #583909 15th Feb 2021 7:52pm
322BLL
Estonia
If I am not mistaking now, did't this happen when you pull the blower relay out or was it the fsr plug?
When I had blower not working regularly(for some reason it happens always on winter) there was way to get it working on max and it stayed on after locking the car.
Changed the fsr first but it was not the solution and few days later also blower motor.
Post #584143 17th Feb 2021 12:07pm
bwelton
Currently with the FSR in, the bower is on Full, even when the car is locked i.e. battery drain...
If I pull the FSR Out then the blower stops. I have an new FSR arriving today, so will see if that fixes it... -------------------------------------
MY 2012 4.4 TDV8
Post #584144 17th Feb 2021 12:11pm
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
When my FSR failed the blower was on full speed all the time even with ignition off and car locked. New FSR cured mine so good luck 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #584147 17th Feb 2021 12:28pm
bwelton
Just inserted the new FSR and the Blower is no longer on Full all the time. Blower control apears to have reverted to normal Very Happy
I'll see how it gets on in the following weeks. -------------------------------------
MY 2012 4.4 TDV8
Post #584170 17th Feb 2021 3:34pm
bwelton
I’ve found with the new FSR from Amazon, it only increments the Blower speed on the first 3 increments of the Blower Speed.
https://www.amazon.co.uk/gp/product/B07VGR...&psc=1
I returned the FSR to Amazon and re-ordered another of the same type and found the same problem. I don’t know if there are cheap Chinese FSR’s or if it could be something else ?
Has anybody else ever found an FSR only working on the first 3 speed increments ? -------------------------------------
MY 2012 4.4 TDV8
Post #584735 21st Feb 2021 6:37pm
Arbuckle
United Kingdom 2012 Range Rover Westminster 4.4 V8 Fuji White
Just some thoughts.
Partial speed operation seems to be related to some alternative market models (according to Amazon reviews)
When testing my original (thought to be faulty) item in the lab, I discovered the output varied in an analogue manner in response to a variable input. It worked exactly as it should.
ie internal resistance decreases as the applied voltage increases.
I am guessing the voltage fed to the FSR comes from the control ECU, according to the position fan speed control knob, rather than direct from the knob. If this were not so, the remote heating could not control the fan, as it clearly does.
A test for the motor itself could be short circuit the FSR power connections, causing full current to motor. If it runs at full speed, it is the FSR. If not, it is the motor.
I also think the ECU gets confused as to the presence of the FSR.
After the battery has been disconnected during service, the fan does not seem to work.(Has happened twice now)
Disconnecting the FSR plug and reconnecting seems to reset and work fine again.
Crazy new world of computer controlled vehicles. I love the physical switches on my '72 baby. Forty years of progress. 1972-2012
Post #585593 27th Feb 2021 8:41pm
Page 3 of 4 <1234>
