Home > In Car Electronics (L322) > Handsfree microphone
Sportex
England 2008 Range Rover Vogue TDV8 Stornoway Grey
Not sure if right section or if its been covered. I have updated my RR from a MY57 to MY11. The handsfree microphone in the old car was horrible, no one could hear me, although the incoming was fine over the speakers, so not a signal proble. Now having updated by 4 years or so, the situation is the same, sounds great listening to the call coming in, but no one can hear me very well at the other end, claims of sounding like I am in a wind tunnel, or stood next to a train, have you got your windows open etc. I have tried turning all the blowers off, but no improvement. Is this a well known issue and is there a fix? No body told me there would be days like these
L Reg dark purple/burgundy sort of Disco
R Reg very red disco
Bright Silver disco TD5
Sort of bright girly powder blue disco TD5
Gone (a while back) 1999 P38 4ltre Autobiography. 13 miles to the gallon, 10,000 miles to the engine
Gone MY06 RRS HSE Rimini Red
Gone MY10 RRS HSE Purple
Gone 2007 TDV8 Vogue OF Stornoway Grey (In Love again)
2011 4.4 TDV8 Vogue Baltic Blue
MY66 VOGUE TDV6 3.0 Red
Post #419161 22nd Dec 2016 3:30pm
might be worth having a look and see if is well,
Post #419164 22nd Dec 2016 3:40pm
Sportex
Thanks, bit of a numpty, what should I be looking for? No body told me there would be days like these
Post #419167 22nd Dec 2016 3:46pm
mzplcg
Replace the microphone with either a Nokia one or a Bury one. Much better quality. I did this in the L322 and SWMBO's DB9 and it made a huge difference.
Post #419179 22nd Dec 2016 5:06pm
Sportex
Thanks for the advice, any help on best place to buy, and any model numbers to ensure I source correct one? I have a long history and a full drawer of badly procured spares. No body told me there would be days like these
Post #419180 22nd Dec 2016 5:15pm
mzplcg
Well, any decent microphone will do if you do it the way I did. I cut the wire and soldered the new part on but if you're not handy with a soldering iron you would need to source one with the same plug. Most are a 2.5mm mono jack but I couldn't face running the wire from the roof down to the back of the screen so I don't actually know what the FFRR uses. Knowing Land Rover it will be an obscure plug which nobody else uses. I just cut the plug off in the roof area and soldered the wires together.
If you want to replace the thing without soldering I would suggest buying genuine from Dan @ Duckworth Parts. It just plugs into the back of the microphone unit Thumbs Up
Post #419185 22nd Dec 2016 5:37pm
