![]() | Home > In Car Electronics (L322) > Handsfree microphone |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35602 ![]() ![]() |
might be worth having a look and see if is well,
Y. O. L. O. . |
Sportex Member Since: 12 Jun 2010 Location: Up North Posts: 366 ![]() ![]() ![]() |
Thanks, bit of a numpty, what should I be looking for? No body told me there would be days like these
Replace the microphone with either a Nokia one or a Bury one. Much better quality. I did this in the L322 and SWMBO's DB9 and it made a huge difference. |
Thanks for the advice, any help on best place to buy, and any model numbers to ensure I source correct one? I have a long history and a full drawer of badly procured spares. No body told me there would be days like these
Well, any decent microphone will do if you do it the way I did. I cut the wire and soldered the new part on but if you're not handy with a soldering iron you would need to source one with the same plug. Most are a 2.5mm mono jack but I couldn't face running the wire from the roof down to the back of the screen so I don't actually know what the FFRR uses. Knowing Land Rover it will be an obscure plug which nobody else uses. I just cut the plug off in the roof area and soldered the wires together.
