![]() | Home > Technical (L322) > Part of heated screen not working properly.. |
JPHC Member Since: 07 Sep 2015 Location: Kent Posts: 303 ![]() ![]() ![]() |
Anyone else got this? The screen is original LR glass. Heats fine everywhere apart from these 3 small stripes.. They clear eventually, It seems they just take longer! Had to be infront of the driver didn't it |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3658 ![]() ![]() |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
got a couple gone on mine as well, not that bad though the only way is a new screen, so wait for a crack to appear |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
In your first photo, the amount that hasn't cleared is about the amount that does clear in mine |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8369 ![]() ![]() ![]() |
Mine had one solitary wire left in the whole screen that worked, and it was on the passenger side.. |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 473 ![]() ![]() ![]() |
The whole of my driver's side doesn't work whereas the whole of the passenger side does work.
Rewmer Member Since: 14 Jan 2013 Location: Essex Posts: 142 ![]() ![]() |
The first frost since getting mine - exactly the same. Fully defrosted passenger side !!! No7 - 2003 V8 Vogue |
Ahhh the joys!!! Glad it's not just me. Looks like my hammer might come in handy |
If a whole half doesn't work, remove the "A" pillar trim (one screw under the airbag badge then pull off) and check the plugs at the base of the pillar, two plugs like this...
