Home > My Range Rover > 200k 04 Autobiography and 75k 65 VogueSE
Page 1 of 11 123 ... 91011>
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
So my 2004 Autobiography LE, bought in May 2013 with 101k on the clock has just turned over 171k so I thought it was time I shared everything thats happened to it as every repair has been documented. (update July 2018 - now 196k(
I live in West Wales on a small farm where my wife breeds horses, and I run my own IT consulting company, working with large banks and insurance companies predominately on their IT strategy. This often means a Mon-Fri commute to Manchester, London, Birmingham or abroad so I am almost always trekking up the M4 on a Sunday night and Friday evening. I used to have a flat in Berkshire which was my base, but have recently changed flats for one in Wimbledon in South London as more of my work is City based. South Circular on a Sunday night and Saturday morning!
So in 2013 after a string of Jaguar XJ's I decided I could finally justify running a Range Rover. I knew it had to Petrol and mileage wasn't a concern - my last 3 Jags had all been bought for pennies with about 100k on the clock each and sold about 18months later at 150k with very little other than routine servicing needing done. I knew buying a 100k L322 would be an expensive maintenance affair but I have a very good local mechanic who does mates rates (also useful as he'll pick it up on a Saturday morning and drop it back on a Sunday afternoon when it needs work). I wasn't concerned about fuel consumption as buying at the bottom of the depreciation curve I have no finance, no interest and very minimal depreciation and plenty left in the kitty!
So in May 2013 I finally found the one I wanted. It was a 2004 04 plate BMW engined 4.4 V8 Autobiography LE. The LE element was a limited edition run of 125 in Java Black or Zambezi Silver with Autobiography trim, 20in wheels, black leather and an optional factory fitted DVD headrest DVD system. Although mine wasn't fitted with the factory system it did come with an aftermarket system installed. This one had 101,697 on it, silver with black leather and was immaculate other than a bit of rust on the upper tailgate seam and with a full service history and brand new MOT. It was for sale by a small business near where I work who did car leasing deals from the front room and had taken this as a trade in as a favour for a good customer and it was up at �9,000. I had been watching it for a few weeks (middle of May, very hot early summer, petrol was �1.30 a litre) and hadn't sold and it had dropped in price to �8k. I went to see it and made an offer of �7,000 on it, reasoning that I would then have around �2k in case anything needed done and said I was in no hurry. A few days later they rang back and said I could take it for �7,250. It was mine. I picked it up that evening from the office I was working, drove 30 miles to Heathrow, parked it in the long term and went to Paris for 4 days on business.
I became really busy over the next couple of weeks with multiple London and Manchester trips so it didn't go for a checkover until three weeks later. Over the next few weeks a number of preventative maintenance items were pencilled in.
103,634 - Full Service, oil, air, pollen filters, sparks, coolant, brake fluid and new coolant expansion tank to cure a tiny coolant leak from the tank seam and a gearbox flush
103,799 - Rocker Cover Gaskets, Rear Discs and Pads, Dashboard pixels
I then experienced my first breakdown in the RR when the alternator failed climbing the hill out of Aberystwyth.
104,451 - New Alternator, drive belt, and while it was in a new radiator fitted and upper hub carrier bushes on the rear.
I then when on a spree over the next few months, updating the sat nav for the Mk4, upgrading to digital TV system and patching into the rear headrests as well and a reversing camera. I also installed a detachable towbar.
108,311 - New Air Suspension Compressor
114,300 - New Battery
115,527 (Dec 13) - Service - Oil and Air Filter and a new Gearbox oil cooler so coolant change as well
119,190 (Feb 14) Lower hub carrier bushes, front brake pads, a/c belt
121,657 (Apr 14) Breather Hoses
122,002 (Apr 14) New Pirelli Scorpions on the front, fixed Steering Wheel reach with new nylon clip
And to complete the first year, at 125,398 exactly a year after buying a fresh MOT
126,433 (Jun 14) OSF Suspension Strut
128,493 (Jul 14) Service - Oil, Air, Pollen, Fuel filters and new upper arm bushes
Outside my flat in July 2014 in Reading parked next to a Shogun I just bought waiting to get taken home to Wales
130,339 (Aug 14) NSF Suspension Strut
131,720 (Aug 14) New Pirelli Scorpions on the rear
132,888 (Sep 14) Water Pump (not usual mechanic as started leaking while on business trip)
133,781 (Oct 14) Upper and Lower Hub Carrier bushes - again, Breather hoses (again although put Silicone ones on this time), front and rear brake pads, new handbrake shoes
137,567 (Dec 14) Front Anti roller drop links
140,749 (Jan 15) Service - Oil, Air, Coolant, Pollen, Fuel filter, Brake fluid,
(Feb 15) Accident on M4 which you can see the dashcam footage in the topic - Dashcam saved my insurance)
As part of the bodyshop work I paid to have the rear tailgate rust fixed as I had never got around to getting it done.
141,412 (Mar 15) New Pirelli Scorpions on front
142,863 (Apr 15) Front Brake pads and discs, front and rear diff oils, transfer box oil
143,102 (Apr 15) AC Belt and Tensioner, Aux Belt
144,289 (May 15) New Pirelli Scorpions on the rear
And so completes the 2nd year of ownership with a new MOT at 144,463
150k!
152,217 (Nov 15) Oil and Air Filter and a new headlight wiper to fix a battery drain
Feb 16 - Bodyshop rectification work on some of the resprayed panels after accident
156,391 (Mar 16) Front and Rear brake pads, Lower front suspension arms, oil cyclone
157,003 (Apr 16) PCV Valve
And third year completed - MOT at 159,244 in May 16
162,700 (Jul 16) Windscreen replacement
162,956 (Jul 16) Breakdown - fuel pump failed
168,348 (Oct 16) Service - Oil and Air Filter, Gearbox oil and filter
169,493 (Nov 16) Rocker Cover Gaskets, New sparkplugs
169,548 (Nov 16) Breakdown - Water pump failure (complete bearing failure after only 35k - presume garage didn't fit OEM)
170,395 (Dec 16) FSR replaced to fix battery drain and new battery (slight misfire traced to low battery voltage)
170,992 (Dec 16) Rear Stabilisers - these were a pig to fit - had three attempts over different weekends as completely seized
173082 (Jan 17) Pirelli Scorpion x 4
175500 (Feb 17) Replacement passenger side window and back window
180,000 (May 17)
and then the next day it went for its MOT and service
180105 (May 17) Service & MOT - 2 advisories - corrosion on rear brake pipes and a minor oil leak.
183451 (May 17 Drivers Side tie rod end, rear brake shoes, oil separator pipe (LLY00110), rear brake pipes
184811 (June 17) Rear Wheel Arches rubbed down and resprayed
187338 (Aug 17) Fuel Sender Unit
193306 (Nov 17) Service (Oil & air filters) and a new headlight wiper (again). Also fixed replaced the wiper linkage which came loose on the M4 and had a temporary clip
195664 (Jan 17) New coolant top hose which let go when towing - stupid all in one piece design - whats wrong with a jubilee clip
196095 (May 1Cool MOT and new pads and discs all round
197900 (Apr 19) Service, MOT, headlight wiper motor, track rods and rear hub bush
Mountain Bike Transport
Pressed into farm work
At Twickenham
Horsebox towing
Long run home from picking up new farm machinery in Derby
So in nearly 3 and half years, I reckon I've lost just �3k in depreciation, but spent a fortune on parts and fuel. I've loved every minute of owning my RR and here is to the next 70k.
I have my eye on a 2012 4.4TDV8 Autobiography but even I'm struggling on the man maths for now.
I hope this has been interesting, and also a helpful guide to the sort of costs/maintenance running an older L322 may bring - especially as the prices are falling on the early ones to sub �5k they become attractive purchases for the unwary. I know mine had been looked after before I had it and I've definitely looked after it in my ongoing ownership, but I can't begin to imagine the sorts of faults that are going to start costing unsuspecting buyers attracted by lower prices to vehicles which haven't necessarily been as well looked after in the last few years. As values fall, so can the willingness to maintain.
Nick. Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #417820 14th Dec 2016 12:03am
Jase71
Australia 2017 Range Rover Vogue TDV6 Santorini Black
What a fabulous write up Nick. Really enjoyed reading! Many thanks for sharing. Mine has just clicked over 105k miles so good to know the sort of normal wear and tear issues likely to pop up.
Jase
Post #417846 14th Dec 2016 12:05pm
great story.. Thumbs Up ... - .- -.
Post #417847 14th Dec 2016 12:06pm
builder1966
England 2004 Range Rover Vogue Td6 Adriatic Blue
plus one great reading
Post #417848 14th Dec 2016 12:08pm
WillyT
United Kingdom 2017 Range Rover Vogue SE SDV8 Carpathian Grey
+1. Very good
Post #417849 14th Dec 2016 12:15pm
builder1966
although I didn't think they made a autobiography in 2004 thought only a vogue vogue se and hse where produced that year?
Post #417853 14th Dec 2016 12:39pm
davidsmith1307
Introduced Sept 2003 for 2004MY from memory.
Post #417860 14th Dec 2016 12:58pm
nicksaab
It's not a full Autobiography - it's known as an Autobiography LE which was 125 units made in November 2003 as a special edition. All were petrol V8's and the only optional deviation from the fixed spec was a factory rear entertainment system - models with that fitted are known as Autobiography LE (DVD). Only 2 colour choices and they were not made by Special Vehicles but carry the autobiography logos except for the Special Vehicles plate on the front suspension strut. Somewhere I have a copy of the press release and brochure - as soon as I get time I will scan it in.
I also believe but don't have evidence that this limited edition run was started to generate interest in the SV Autobiography programme which was launched at the same time Current Fleet:-
Post #417865 14th Dec 2016 1:25pm
builder1966
cheers nick love to read it very interesting
Post #417866 14th Dec 2016 1:28pm
Giantlandyman
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
Nice write up. I enjoyed reading than.
As to the 4.4 TDV8,
Post #417892 14th Dec 2016 4:01pm
nicksaab
Many thanks for the positive feedback - I wasn't sure if anyone would find it interesting so thanks for that.
As promised I dug out the press release from Land Rover at the time - there was only 125 made (originally I had thought it was 175). Interestingly enough (to me) it looks like most, if not all were made prior to being released - mine has all the components on it date stamped the last week in October 2003, but it wasn't registered until 30th March 2004 at Guy Salmon in Sheffield. The last sentence in the press release implies there would be cars at each dealership on 8th November 2003 so I'm assuming at least one was sent to each dealer as a showroom car?
Anyway looks like they are pretty rare - I understand only about 80 of them are still on the road and a further 15 are on SORN, so 30 have been scrapped or exported.
PRESS RELEASE
PRESS RELEASE PICTURE
BROCHURE
 Current Fleet:-
Post #417953 15th Dec 2016 12:31am
builder1966
cool thanks for showing very intresting
Post #417960 15th Dec 2016 3:13am
nicksaab
To end off 2016, at 172,204 miles absolutely filthy having spent a day moving horse bales from my supplier to home.
 Current Fleet:-
Post #420404 31st Dec 2016 6:15pm
builder1966
happy new year nick
Post #420406 31st Dec 2016 6:19pm
Good to see one being used as it should be! There is nothing that can't be fixed with a hammer😜😜
Post #420414 31st Dec 2016 6:32pm
