Home > Technical (L322) > Drivers door mirror |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 830 |
Have you done a battery disconnect and ECU reset?
13th Dec 2016 8:35pm |
Benner91 Member Since: 17 Oct 2015 Location: Belfast Posts: 87 |
How do you do a ecu reset
13th Dec 2016 9:01pm |
Normally disconnect both the battery negative and positive cables after waiting the prescribed time (in the wiki), then wait a good 10 minutes then touch the two cables together for about a minute.
13th Dec 2016 9:07pm |
Brilliant
13th Dec 2016 9:29pm |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
Check and recheck your connectors if you removed the door card. Loads of peeps had the same, it's a case of making sure the connectors are pushed fully in.
14th Dec 2016 4:39am |
RRV78 Member Since: 15 Sep 2016 Location: Truro Posts: 203 |
I went through exactly the same with my passenger side mirror when doing the cable. After having the door card off several times I found I had to remove the grey retaining clip off the mirrors multi plug and push it in firmly and all worked fine and still does. |
14th Dec 2016 9:28pm |
