Home > Technical (L322) > alarm reset L 322 |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
First things to try:
10th Dec 2016 2:16pm |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 |
I've done the same...dead battery.opened door with key and alarm sounds but you can't turn key in ignition...as above charging battery and retry! I found the key not turning was simply because there was no power...once batterys charged it car gets a jump start it should turn .. |
10th Dec 2016 2:30pm |
gillech Member Since: 03 Nov 2015 Location: montreux Posts: 18 |
thank you for your help.
10th Dec 2016 2:50pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3233 |
You can charge the battery connected to the car BUT the point of taking off both connectors and touching them together, as described above, is to reset the system. John
10th Dec 2016 3:03pm |
