Home > Technical (L322) > alarm reset L 322
gillech
Switzerland 2003 Range Rover HSE 4.4 V8 Adriatic Blue
alarm reset L 322
Hi
i found my battery flat, had to open door mechanically,as remote key wouldn't unlock doors neither disable car alarm.
i tried an emergency start using auxiliary battery, car alarm went off ,but before i could start the engine, all electrical supply went off.
the ignition cylinder is blocked , key gets in and out but can't turn to ignition.
please advise what i should do
- reset the car alarm , and how it should be done ?
-try to load the battery ?
thank you
LR 322 2003 V8 4,4
Post #417366 10th Dec 2016 1:22pm
First things to try:
Disconnect battery and leave disconnected for @ 1 hour at least
If you want to touch the two terminal connectors together (helps to clear ECU's ?)
Charge the battery (or replace if dead)
Once these things done, reconnect and see what you have.... .
Post #417373 10th Dec 2016 2:16pm
alistairh
I've done the same...dead battery.opened door with key and alarm sounds but you can't turn key in ignition...as above charging battery and retry! I found the key not turning was simply because there was no power...once batterys charged it car gets a jump start it should turn ..
Post #417380 10th Dec 2016 2:30pm
gillech
thank you for your help.
is it absolutely necessary to disconnect the battery, or
is it possible to load the battery without disconnecting it from the car (3 months ago i could recharge the battery without disconnecting it, using a smart battery charger )
thank you
Post #417385 10th Dec 2016 2:50pm
Weegie
You can charge the battery connected to the car BUT the point of taking off both connectors and touching them together, as described above, is to reset the system. John
GAP iiD BT
Post #417387 10th Dec 2016 3:03pm
