![]() | Home > Technical (L322) > alarm reset L 322 |
First things to try:
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
I've done the same...dead battery.opened door with key and alarm sounds but you can't turn key in ignition...as above charging battery and retry! I found the key not turning was simply because there was no power...once batterys charged it car gets a jump start it should turn .. |
gillech Member Since: 03 Nov 2015 Location: montreux Posts: 18 ![]() ![]() ![]() |
thank you for your help.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3244 ![]() ![]() ![]() |
You can charge the battery connected to the car BUT the point of taking off both connectors and touching them together, as described above, is to reset the system. John
