![]() | Home > Technical (L322) > engine cleaning tips |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 491 ![]() ![]() ![]() |
You can buy specific engine degreaser products to do this. WD40 on a rag will remove a lot of the gunk though and clean it up! Might be worth starting with that and see how bad it is before shelling out on fancy products! |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
Not having a pressure washer is a good thing, what engine is it? |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
4.4 v8 petrol |
ok, me too.
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 830 ![]() ![]() ![]() |
I had a tin of Gunk lying around so poured some of that into a bowl and pinched one of the wife's pot scrubbing brushes, the ones with a long handle.
the oil doesnt make its way to the drive because of the undertray and either burns off on the exhaust or gets spread around by the power steering pump depending on where it is.
I'd probably get a thick ear for punching my girlfriend's brush ![]() |
Just to qualify earlier remarks: NOT a good idea to fire a pressure washer at the engine bay!! |
Gentlemen thankyou |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3660 ![]() ![]() |
You might find that some Brake and clutch cleaner is a good alternative.. you should be able to pick up 5 lts for around a tenner from a car spares place that isn't Halfrauds.. An independent motor factors is the best source, someone like this http://www.pentlandcomponents.com/ Yesterday I couldn't spell Engineer... Today I are one!
Gunk, a brush, and a hose where you can control the flow right down to a trickle.
Punch, pinch it's all the same to my missus |
