Home > Technical (L322) > engine cleaning tips
Page 1 of 3 123>
alistairh
Hi folks...im going to clean my oily mess of an engine to try and figure out wear the small leaks coming from...whats the best product to degrease and remove the oil...i don't have a pressure washer so its going to have to be done by hand... Thumbs Up
Post #417327 10th Dec 2016 9:27am
kbald
You can buy specific engine degreaser products to do this. WD40 on a rag will remove a lot of the gunk though and clean it up! Might be worth starting with that and see how bad it is before shelling out on fancy products!
Post #417336 10th Dec 2016 10:04am
holidaychicken
Not having a pressure washer is a good thing, what engine is it?
Post #417337 10th Dec 2016 10:08am
alistairh
Thumbs Up Good shout! Have plenty lying about..area under cam covers has years of Old oily gunk from an old leak..wanting it spotless before I renew gaskets...thanks
Post #417338 10th Dec 2016 10:09am
alistairh
4.4 v8 petrol
Post #417339 10th Dec 2016 10:09am
holidaychicken
ok, me too.
Finally cured all my leaks
cam covers, everybody knows that one
pcv hoses breaking down
vanos solenoid seals easy job
front timing cover gaskets (finally solved) not very easy
timing chain tensioner washer not common
i have a little hand held steam cleaner that is quite good for small jobs.
If you spray water into the engine bay it will cause loads of problems i reckon so a plastic friendly spray degreaser would probably work well
http://www.ebay.co.uk/itm/2-x-JIZER-ENGINE...XqdJD4e2Tw
Post #417343 10th Dec 2016 10:49am
alistairh
Thumbs Up I'm going to write down your list and work through them to find my leaks...cleaning it today then pcv system tonight and tomorrow..cam cover gaskets after that...my leaks small and doesn't foul my driveway but lower engines a mess and once car heats up the smells noticable..did you do all the work yourself?
Post #417348 10th Dec 2016 10:56am
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
I had a tin of Gunk lying around so poured some of that into a bowl and pinched one of the wife's pot scrubbing brushes, the ones with a long handle.
Then brushed it onto the affected areas, left it for about an hour or so, went back scrubbed it again with a bit more Gunk. I then used the same brush but with a bowl of fresh water and it's nice and clean Thumbs Up
Not much mess either and all you have to do later is to hose down the driveway, oh and I did get a thick ear from the wife for pinching her brush Big Cry ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #417354 10th Dec 2016 11:51am
holidaychicken
the oil doesnt make its way to the drive because of the undertray and either burns off on the exhaust or gets spread around by the power steering pump depending on where it is.
I did my cam covers a while back which ideally you want to give them a really good clean up as the paint where the seals sit blisters into an oil crusty mess so allow plenty of time. i had mine blasted and powder coated.
check your spark plug bores as well as the inner cam cover gasket leaks and eventually causes a misfire or two.
I then redid everything when i changed my timing chains and guides and valley pan and pcv valve......
Post #417355 10th Dec 2016 11:51am
holidaychicken
UK Marine wrote:
oh and I did get a thick ear from the wife for punching her brush Big Cry
I'd probably get a thick ear for punching my girlfriend's brush Shocked
Post #417356 10th Dec 2016 11:53am
Just to qualify earlier remarks: NOT a good idea to fire a pressure washer at the engine bay!! Shocked .
Post #417357 10th Dec 2016 12:12pm
alistairh
Gentlemen thankyou Thumbs Up ..great tips on the leaks and cleaning engine bay...power washer ideas out my head too Laughing
Post #417359 10th Dec 2016 12:18pm
miggit
You might find that some Brake and clutch cleaner is a good alternative.. you should be able to pick up 5 lts for around a tenner from a car spares place that isn't Halfrauds.. An independent motor factors is the best source, someone like this http://www.pentlandcomponents.com/ Yesterday I couldn't spell Engineer... Today I are one!
Post #417376 10th Dec 2016 2:23pm
mzplcg
Gunk, a brush, and a hose where you can control the flow right down to a trickle.
Remove the under tray covers before starting as this allows the mess to run clear of the car. Don't do the job anywhere near a mains drain either, you don't want this going into the sewers. I tend to spread an old sheet under the engine area to absord as much of the mess as possible and then throw it away afterwards.
Apply gunk with an old spray bottle. Leave for an hour. Apply a bit more and work it with a brush. I use an old washing up brush but anything similar will do.
Rinse with a trickle of water from a hose and keep going with the brush whilst you do. Don't be tempted to use full blast on the hose though, just a trickle is fine and it saves keep changing bowls of water.
Post #417382 10th Dec 2016 2:38pm
UK Marine
Punch, pinch it's all the same to my missus Shocked ______________________________
Simon
Post #417401 10th Dec 2016 4:17pm
Page 1 of 3 123>
