Home > Technical (L322) > Keys and memory seat |
steadyaway Member Since: 28 Feb 2015 Location: West Yorkshire Posts: 184 |
Can anyone tell me if the keys for my 2006 Vogue TD6 should set the seats to different memory positions ie one key for position 1 and the other key for position 2 etc. Thanks. |
8th Dec 2016 7:11pm |
I don't think it was ever an option. My 07 Vogue SE never had that. it did have convenience entry but that was not key related. |
8th Dec 2016 7:41pm |
Thanks for that. I didn't think so but a post on fb suggested it might. I don't think mine has easy access either, however the steering wheel does lift but the seat doesn't retract. |
8th Dec 2016 7:47pm |
Ahhh. Do you recall how to activate/set it please? |
9th Dec 2016 2:49pm |
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 |
Hi On my 06 - set the seat position press the M button on the seat then either 1 or 2 . same process for key 2. However you must remember to lock the car before using the second key. Mine gets confused if you dont lock the car between key swaps. Ie if you use key 1 then lock the car with key 2 when you open with key 2 it does not move the seat to key 2 postion.
9th Dec 2016 2:58pm |
Thanks for that Simon, I'll give that a try. |
9th Dec 2016 3:05pm |
No probs - forgot to say it also changes the steering wheel postion as well |
9th Dec 2016 3:10pm |
9th Dec 2016 3:31pm |
Fatzo Member Since: 11 Nov 2016 Location: Rigny Posts: 82 |
My former TD6 Vogue had it too |
9th Dec 2016 11:50pm |
