![]() | Home > Technical (L322) > Keys and memory seat |
steadyaway Member Since: 28 Feb 2015 Location: West Yorkshire Posts: 184 ![]() ![]() ![]() |
Can anyone tell me if the keys for my 2006 Vogue TD6 should set the seats to different memory positions ie one key for position 1 and the other key for position 2 etc. Thanks. |
I don't think it was ever an option. My 07 Vogue SE never had that. it did have convenience entry but that was not key related. |
Thanks for that. I didn't think so but a post on fb suggested it might. I don't think mine has easy access either, however the steering wheel does lift but the seat doesn't retract. |
Ahhh. Do you recall how to activate/set it please? |
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 ![]() ![]() ![]() |
Hi On my 06 - set the seat position press the M button on the seat then either 1 or 2 . same process for key 2. However you must remember to lock the car before using the second key. Mine gets confused if you dont lock the car between key swaps. Ie if you use key 1 then lock the car with key 2 when you open with key 2 it does not move the seat to key 2 postion.
Thanks for that Simon, I'll give that a try. |
No probs - forgot to say it also changes the steering wheel postion as well |
Fatzo Member Since: 11 Nov 2016 Location: Rigny Posts: 82 ![]() ![]() ![]() |
My former TD6 Vogue had it too |
