Home > Technical (L322) > Keys and memory seat
steadyaway
Can anyone tell me if the keys for my 2006 Vogue TD6 should set the seats to different memory positions ie one key for position 1 and the other key for position 2 etc. Thanks.
Post #417181 8th Dec 2016 7:11pm
mzplcg
I don't think it was ever an option. My 07 Vogue SE never had that. it did have convenience entry but that was not key related.
Post #417187 8th Dec 2016 7:41pm
steadyaway
Thanks for that. I didn't think so but a post on fb suggested it might. I don't think mine has easy access either, however the steering wheel does lift but the seat doesn't retract.
Post #417192 8th Dec 2016 7:47pm
Mine did - both my 03 & 07
Each key used to set the seat to the right position for that driver when you unlocked it - so that by the time you got into the car, the sear was already in the right place.
My L405 doesn't have it & I really miss it
Post #417265 9th Dec 2016 2:47pm
steadyaway
Ahhh. Do you recall how to activate/set it please?
Post #417266 9th Dec 2016 2:49pm
RP123
Scotland 2006 Range Rover HSE Td6 Bonatti Grey
Hi On my 06 - set the seat position press the M button on the seat then either 1 or 2 . same process for key 2. However you must remember to lock the car before using the second key. Mine gets confused if you dont lock the car between key swaps. Ie if you use key 1 then lock the car with key 2 when you open with key 2 it does not move the seat to key 2 postion.
So if you use key 1 to open lock with key 1 the open with key 2 and shut with key 2 its all ok
Simon
Post #417267 9th Dec 2016 2:58pm
steadyaway
Thanks for that Simon, I'll give that a try.
Post #417268 9th Dec 2016 3:05pm
RP123
No probs - forgot to say it also changes the steering wheel postion as well Thumbs Up
Post #417269 9th Dec 2016 3:10pm
steadyaway
Post #417270 9th Dec 2016 3:31pm
Fatzo
France 2011 Range Rover Vogue TDV8 Ipanema Sand
My former TD6 Vogue had it too
Post #417312 9th Dec 2016 11:50pm
