Home > Technical (L322) > How to Find Top Dead Center TDV8
Page 5 of 12 <123 456 ... 101112>
theanswers
Ireland
I'll check the fault codes tomorrow when I get all up and running.
The temperatures today was 4-5 degrees.
Can the diesel ungel? Might be worth filling the fuel filter with good fresh diesel.
Post #416686 4th Dec 2016 10:40pm
sako243
I think it can one it warms up, you might also be able to add the additive manually. Ed
Post #416687 4th Dec 2016 10:43pm
Weegie
theanswers wrote:
I have an IID tool but it's paired to my old Discovery. I must get it paired to the RR tomorrow. That might shed more light on the situation.
Should still read and clear faults as that function is not VIN locked. John
GAP iiD BT
Post #416688 4th Dec 2016 10:44pm
theanswers
Ireland
I put it onto the car today and It said not suitable for this vehicle.
The filter could possible be in a state also. Will know shortly. Hoping it is a simple fix! for once.
Post #416689 4th Dec 2016 10:45pm
Weegie
Ok. Thumbs Up John
GAP iiD BT
Post #416690 4th Dec 2016 10:46pm
andygts
wouldn't hurt to put a new filter on and brim the tank with fresh diesel. Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #416691 4th Dec 2016 10:49pm
hamlet
Ireland 2006 Range Rover HSE Td6 Buckingham Blue
Top job on getting it this far, have done a few Navara engines in the last few years myself and there's nothing like having a go at a job like this yourself.... Thumbs Up
I don't think it's been cold enough over here for the last while to make the fuel gel but personally I'd whip the filter off and have a look at it.
I know some are not a big fan of this stuff but a squirt of easy start into the manifold while cranking might be enough to get it firing and draw more fuel.
If you have a compression tester it would at least put your mind at ease on that front.
I had a similar issue after fitting a new turbo on a Kia Sorento a while ago, running fine and then all of a sudden nothing, turned out to be the pedal position sensor, just damp from sitting up.
Post #416701 5th Dec 2016 12:51am
Also check for sensor faults.
Crank position sensor can result in non starting. Had the same on my van. Thing of it this way, engine wise there is only fuel and compression, if you have both of them then it is likely to be sensor related. There is nothing that can't be fixed with a hammer😜😜
Post #416771 5th Dec 2016 6:50pm
theanswers
Ireland
Hey Guys so I got her on diagnostics tonight. The following error codes where logged.
Vehicle Speed Sensor A
Lost Communication with Instrument control module
Vehicle Communication bus A Performance
Microwave phase lock loop.
After I performed a number of test it still wouldn't work. I clear the faults and the following came back.
Lack of communication with instrument control module.
Also the body processor module is not communicating. Where is this located. As someone mentioned earlier it could be a connection. Can anyone make any sense of the errors?
Thanks lads.
Post #416781 5th Dec 2016 7:47pm
I would start with the engine bay connectors round the large electronics box. Check these first as I presume the bits and bobs in the car haven't been disturbed and you have had the engine out and possibly pulled a cable in the engine compartment.
I would suspect that all the modules are fine and It's probably one loose connection which has caused a cascade of faults. There is nothing that can't be fixed with a hammer😜😜
Post #416785 5th Dec 2016 8:06pm
rar110
G'day mate. Any update? ______________________________
Post #417092 8th Dec 2016 8:09am
theanswers
Ireland
Hey, No luck! Sad
The Mechanic came back today and had a look at her. He changed the fuel filter and checked a few wires. Couldn't see anything amiss! Anyways she is still not starting and I think they are kinda washing there hands of it!
I'm a bit disappointed. I've a strong feeling that there is nothing wrong with the engine! Apart from anything else It would still start with one cylinder down as it prior to being repaired. It's turning over nicely & the big plus is the computer is only pointing to an electrical fault.
I'll check the wires on Monday, as that's the next day I'm free - but apart from that would quick checks could I make! It has to be something simple! I want this car working for Christmas!
Post #417205 8th Dec 2016 10:11pm
hamlet
I've read in a few places about people getting misfires and replacing fuel filters and vehicle speed sensors, I'm not sure what the connection would be, unless the VSS is faulty and sending a spurious reading and the ECM won't allow the engine to fire if it thinks it's going over a certain speed or something like that.
I only say this as I see it threw up a fault of Vehicle Speed Sensor A, just incase they are somehow connected.
I'd give it a blast of easystart to see if it attempted to fire.
Post #417254 9th Dec 2016 12:20pm
theanswers
Ireland
I still haven't got a chance to look at her yet. I'm hoping to have a good at it today. The more I discuss the issue with people the more I realise that it must be an electrical issue (which the computer is point to!). I did try some easy start in her and no luck. It's as if the easy starts ignites, but then the computer still doesn't supply the fuel.
I'm going to check all the electrical cables today or tomorrow that I can see. It must be one of them or then possibly a sensor.
Post #417701 13th Dec 2016 9:35am
sako243
I learnt something yesterday (from watching Fast N Loud... Whistle )
If it doesn't even fire it might well be the MAF sensor, if it fires and then stops might be the manifold pressure sensor. Ed
Post #417752 13th Dec 2016 5:06pm
