Home > Technical (L322) > How to Find Top Dead Center TDV8 |
theanswers Member Since: 30 Jul 2012 Location: Ireland Posts: 305 |
Ok lads.
4th Dec 2016 5:34pm |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1347 |
Did you move the fuel injection pump at all during the rebuild if so did you retime it to the engine
4th Dec 2016 6:28pm |
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 |
Hiya
4th Dec 2016 6:57pm |
I don't think it's the fuel injection pump. It can only fit on one way and as you said yourself it ran perfect for a few miles.
4th Dec 2016 7:17pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
Start either easy stuff, check all the fuses. I agree it sounds fuel related. If a sensor somewhere is not reading right the ECU won't deliver fuel. Again check the easy to access sensors and connectors first eg MAFs next to air filter.
4th Dec 2016 8:08pm |
I have an IID tool but it's paired to my old Discovery. I must get it paired to the RR tomorrow. That might shed more light on the situation.
4th Dec 2016 9:47pm |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 610 |
Do you get fuel at the filter? Can you crack one of the pipes off and turn it over? If you're not getting fuel there then perhaps the lift pump in the tank? Ed |
4th Dec 2016 9:55pm |
Yes. There is fuel at the filter! I wonder would the fact that the fuel is old be making a difference. It's from April? |
4th Dec 2016 9:59pm |
What's the temperature like?
4th Dec 2016 10:05pm |
You could be on to something. But surly the fact that she is pumping fuel out the lines it would be OK? There is approxmetely half a tank in it, should I add new fuel?
4th Dec 2016 10:28pm |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 354 |
^^^ very plausible. At these temps you're probably getting some fuel through the filter so you can smell it coming out of the exhaust but not enough being injected into the cyclinder to ignite under compression.
4th Dec 2016 10:29pm |
It's 7 - 12 degrees tomorrow? That is hardly too cold??
what were the temps today though and last night? Current
4th Dec 2016 10:35pm |
Some fuel may be coming through but not enough. The Series started and ran fine only until you floored it or went up hill.
