Home > Technical (L322) > DREADED FBH |
BOBCUSSEN Member Since: 25 Nov 2012 Location: DORDOGNE Posts: 296 |
hi folks
1st Dec 2016 11:37am |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 |
This will help diagnose the problem http://www.the75andztclub.co.uk/forum/showthread.php?t=71982 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car! |
1st Dec 2016 12:08pm |
HI graeme
2nd Dec 2016 9:31am |
hi folks
4th Dec 2016 10:37am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3236 |
Bob the little aluminium finned radiator is the fuel cooler.
4th Dec 2016 11:12am |
hi john
4th Dec 2016 12:36pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
The fuel pump for the FBH is located in one of the most inaccessible places on the car, behind the upper wishbone of the RHR suspension. One can just about get a hand or finger to it to test if it is running/ticking. If you are really in the mood you can (CAREFULLY!) drop the subframe @ 2in on that side for better access.
4th Dec 2016 1:09pm |
ouch that sounds a job;
4th Dec 2016 1:36pm |
Pretty certain the answer is NO .
4th Dec 2016 2:14pm |
Drawing from RAVE on location of pump
4th Dec 2016 2:21pm |
OK. well i will hav a look about popping the wheel arch cover off etc, i expect, looking at the posts, it is probably the PCB at fault, so hopefully it all comes out wwithout too much trouble
4th Dec 2016 2:27pm |
hi folks, ok i have decided i would rather have the FBH up and running than not, even if it does not get a lot of use;
6th Dec 2016 12:28pm |
TomCobbly Member Since: 29 Jun 2016 Location: Guildford Posts: 122 |
You might find this file in Wiki very useful. Reading it I note that the fuel pump doesn't start running until 30 seconds into the start up sequence. I'm guessing if the glow plug has failed and the system fails to detect a flame then the fuel pump will be shut off.
6th Dec 2016 2:29pm |
HI TC
6th Dec 2016 2:44pm |
