Home > Technical (L322) > engine temperature
Andy
engine temperature
I changed my alternator on the TD6 last week and I found the easiest way to do this was to remove the radiator rather than the power steering pump. Whilst the rad was out, I decided to get it leak tested as I keep losing coolant.
The rad was tested and was fine. I refitted it and topped it up with fresh coolant. It now seems to take a while to get up to temperature and i was wondering if the system needs bleeding etc
I never found the source of the coolant loss to this day. I put a Snap-On pressure tester on the car which also detects gases from any potential head gasket fail. There's no coolant on the floor or in the oil and no sludge, I have no idea where its going unless its leaking on the move and evaporating!
Post #416735 5th Dec 2016 12:56pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Could be a micro fracture in your expansion tank, they tend to crack at the corners. Best way to check is to get it up to temp and hold a small mirror or such and you'll see steam and moisture on the cold mirror.
Best of luck. ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #416744 5th Dec 2016 1:53pm
Andy
Yes, but that would show up on a pressure test wouldn't it?
Post #416761 5th Dec 2016 4:19pm
UK Marine
Possibly but it has to be hot to get the expansion tank to expand enough to leak. ______________________________
Simon
Post #416764 5th Dec 2016 4:28pm
miggit
there is a bleed screw on the EGR cooler at the front of the engine, another on the rail that runs down the side of the head and a third on the header tank... so yes they do need bleeding, they also need to be run with the cap off until they get to temp and topped up as you go.....
some more info on the bleed screws here http://www.fullfatrr.com/forum/topic36241.html Yesterday I couldn't spell Engineer... Today I are one!
Inventor of the 'Guide-o-Matic automatic wheel alignment tool'
Former long term L322 owner, Up/Down graded to a Classic Tractor!
Post #416830 6th Dec 2016 7:29am
