Home > Technical (L322) > 2010 4.4 Autobiography. Low battery, please start engine.
Mistercorn
United Kingdom 2010 Range Rover Autobiography 4.4 V8 Java Black
I have only had the car for a week. I saw this message after I first used the FBH. I assumed the car had sat for a while and the battery was a bit low but I get it even when the car has just sat for a while. Yesterday I drove it 150 miles, this morning when I unlocked I had the message. The engine turns over quickly and starts well. The battery is marked as an AGM Land Rover one, I am wondering if it might be the original one. Is there anything which can be done usefully for diagnostics or is it just a case of get on and chnge the battery then reset the charge monitor with an IIDtool?
MC
Post #414428 19th Nov 2016 9:52pm
miggit
There is a software upgrade that sorts this problem out, from what I can make out the battery monitor is set too high and the slightest drop in voltage triggers the message.. Check with the steatlers who service the car, they should be able to tell if the update has been done. If the upgrade has been done then you'll be needing a new battery Sad
That's the bad news, but on a brighter note most "flat" battery issues have been fixed with the software Very Happy Yesterday I couldn't spell Engineer... Today I are one!
Post #414436 19th Nov 2016 10:24pm
Mistercorn
Thanks for that, I'll give them a call on Monday. Loving the car, smoother and quieter than the 3.6 with some extra poke when needed, a proper luxury car.
MC
Post #414439 19th Nov 2016 10:30pm
you need to change your car profile sir... ... - .- -.
Post #414440 19th Nov 2016 10:31pm
Mistercorn
Done Smile
MC
Post #414442 19th Nov 2016 10:44pm
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
When changing battery on my old 745 to agm I had to register it in the ecu, was able to do it with autel, and bmw inpa
Post #414516 20th Nov 2016 2:12pm
Mistercorn
It seems there might be a little bit more to the story. I drove the car for 3 hours on Saturday morning and parked it up around 12:30. I then went to the car just before 6am this morning (Monday) and it wouldn't unlock. I can see that the red light around the hazard light switch is on, but it appears that the battery is dead.
I am contacting the garage I bought the car from as I have had it less than a week to see how they want to deal with it. It sounds like possibly a battery drain issue which will have also killed the battery. I didn't bother opening the car and jump starting it as it was dark and raining, I just took a different car instead and will investigate later. Not particularly happy, but this is my third RR so I kind of know what to expect. Rolling Eyes
MC
Post #414613 21st Nov 2016 8:30am
miggit
Shocked That doesn't sound good for the battery.... still better to find out it's a dud a week after you brought it than 7 months down the road, at least it should be the Dealers pain to sort it Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #414661 21st Nov 2016 4:37pm
Baltic Blue
Is their a TSB number for this software upgrade please.
I get this message if I sit listening to the radio for 10minutes, but fingers crossed, no other reason to doubt battery.
Post #414664 21st Nov 2016 4:49pm
Mistercorn
It sound like it is just the battery. After that was changed and the fault codes all cleared there was one which came straight back EGR fault A. So it sounds like there is an EGR valve issue as well. Also the lens is missing from the camera on the passenger side door which means it just doesn't work properly.
MC
Post #415209 24th Nov 2016 9:58pm
