![]() | Home > Technical (L322) > 2010 4.4 Autobiography. Low battery, please start engine. |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
There is a software upgrade that sorts this problem out, from what I can make out the battery monitor is set too high and the slightest drop in voltage triggers the message.. Check with the steatlers who service the car, they should be able to tell if the update has been done. If the upgrade has been done then you'll be needing a new battery |
Mistercorn Member Since: 01 Feb 2014 Location: Nottingham Posts: 109 ![]() ![]() ![]() |
Thanks for that, I'll give them a call on Monday. Loving the car, smoother and quieter than the 3.6 with some extra poke when needed, a proper luxury car.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35641 ![]() ![]() |
you need to change your car profile sir... ... - .- -.
Done |
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 ![]() ![]() |
When changing battery on my old 745 to agm I had to register it in the ecu, was able to do it with autel, and bmw inpa |
It seems there might be a little bit more to the story. I drove the car for 3 hours on Saturday morning and parked it up around 12:30. I then went to the car just before 6am this morning (Monday) and it wouldn't unlock. I can see that the red light around the hazard light switch is on, but it appears that the battery is dead.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3818 ![]() ![]() ![]() |
Is their a TSB number for this software upgrade please.
It sound like it is just the battery. After that was changed and the fault codes all cleared there was one which came straight back EGR fault A. So it sounds like there is an EGR valve issue as well. Also the lens is missing from the camera on the passenger side door which means it just doesn't work properly.
