Home > Technical (L322) > Transfer case fault |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
I am guessing you have an 02-05 but there has been a few posts recently about the reluctance to shift, sounds like you use low quite regularly ?
11th Nov 2016 4:28am |
littlecub Member Since: 02 Apr 2013 Location: Ulverstone,Tassie Posts: 325 |
Iid tool .
11th Nov 2016 4:37am |
See what he says, the high / low shift is done internally in the transfer box powered by the motor and can get sticky if not used regularly but the fact it worked when you restarted does point towards an electrical fault. i can't find anything on that error code and the transfer box shift motors do have a finite life and there are now refurbished units available on the net. |
11th Nov 2016 6:48am |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 |
May not be the motor, but the fingers used for sensing motor position. They rub away at the contact surface in the high range position and then fail to make proper contact
11th Nov 2016 2:17pm |
Thanks bsl.
11th Nov 2016 9:54pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
This might be of help.. I did find a likely looking replacement pot on a GM shift motor... reckon the Holden will be the same... might be able to cop hold of one and do a comparison... (I'd be looking for either SH or a dud from a tranny shop.. as it's unproven tech.. who knows )
12th Nov 2016 1:54am |
