![]() | Home > Maintenance & Mods (L322) > After market rear lights - can't remove... see pics |
Try cutting a long thin wedge of soft timber, inserting it into the joint between the front edge of the lights and the bodywork and gently tap it into the gap. The lights should drive towards the rear and then come off. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35485 ![]() ![]() |
the brake bulb is led so possibly you have been very unlucky and the led has actually become faulty... i'd first look at the wiring to it.. ... - .- -.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8374 ![]() ![]() ![]() |
I presume that 3rd picture is of the upper front corner of the drivers side rear light... the threaded part in there leads me to think maybe they drilled all the way inside the car and fixed it with a screw, remove the rear fuse box cover inside and see if you can see the other side of that area....
Josh Wyatt Member Since: 10 Jan 2011 Location: Oxford Posts: 77 ![]() ![]() ![]() |
That style of light is the genuine factory fit for 2010 models onwards. It appears yours is a 2003, when fitting the later lights to earlier models modification to the wiring is required.
phillips321 Member Since: 05 Nov 2016 Location: Countryside Posts: 50 ![]() ![]() ![]() |
Ok so i do have some sort of converter box which has been cut into. The only odd thing is all the wires except for the brake light has been but into (blue/black and black/blue). So the control box is not interfering with the brake light in anyway as far as i can tell.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7970 ![]() ![]() ![]() |
All LED - as already posted, it's an upgrade to the 2010 & onwards unit - but they didn't operate like bulbs with a wire for each, so a convertor box was required.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3658 ![]() ![]() |
&feature=youtu.be Yesterday I couldn't spell Engineer... Today I are one!
