Home > In Car Electronics (L322) > Cigarette sockets staying active when locked? |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 830 |
I'm not sure but don't the sockets power down after 16 minutes, just like the lights if you leave a door open.
6th Nov 2016 6:35pm |
phillips321 Member Since: 05 Nov 2016 Location: Countryside Posts: 50 |
This is appreciated, i'm trying this out now, will go back outside at 1900 and confirm either way
6th Nov 2016 6:46pm |
Whatever you do don't open the doors as that might wake up the sockets. ______________________________
6th Nov 2016 6:58pm |
Car's been outside for the past 20 minutes so will go and check now. I haven't touched it or opened any doors.
6th Nov 2016 6:59pm |
Spelunker Member Since: 02 May 2016 Location: Nottinghamshire Posts: 248 |
Im sure I saw a post going through how to change the sockets to ignition switch controlled..... QUID FACIUM TIBI
6th Nov 2016 7:00pm |
Just checked and the one near the key is still on Not sure how long to leave it.
6th Nov 2016 7:07pm |
Try the gear selector position lights, they should go out after the allotted time of 16 minutes. Be careful though as I've found that trying the tailgate release switch on the tailgate wakes up the gear selector position lights. Not sure if that wakes everything else though........... ______________________________
6th Nov 2016 7:14pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
The sockets are either on all the time or ignition controlled on a 2003 car, no delay after the ignition is switched off.
6th Nov 2016 7:15pm |
Hi thanks for the help. Here's the rear fuse box:
6th Nov 2016 7:36pm |
I've looked at the wiring diagram and it appears that both the cigar lighters and the accessory sockets are live all of the time. They just go from the battery to the fuse boxes then to the sockets...
6th Nov 2016 7:48pm |
@ uk marine, I agree that's what the wiring diagrams show but cars do seem to vary for some reason ie cigar sockets can be ignition controlled or not, same with aux sockets. My cigar sockets are permanently live but my aux sockets are ignition controlled.
6th Nov 2016 8:10pm |
just tested, pulled the yellow one out and the 12v socket went off
6th Nov 2016 8:21pm |
The easiest way is to ask for one without a diode.
6th Nov 2016 8:31pm |
I only checked the single one that was plugged in (next to gear lever).
6th Nov 2016 8:34pm |
