![]() | Home > In Car Electronics (L322) > Cigarette sockets staying active when locked? |
phillips321 Member Since: 05 Nov 2016 Location: Countryside Posts: 50 ![]() ![]() ![]() |
Ok, but which one? I don't want to pull something that's going to cause me any problems.
The one imeadiatly to the right of the removed yellow one serves the rear fan blower so you should be able to use that without incurring any problems. |
Great, just tried that and it worked, as expected. Key on, 12v on. However it was a 5 pin. I guess ill get that type.
Fuse 1 on the rear fuse board feeds the two cigar sockets and the front accessory socket.
Had a think, don't need to wait until tomorrow.
jjcbollen Member Since: 25 May 2016 Location: Maastricht Posts: 6 ![]() ![]() ![]() |
Hi,
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 899 ![]() ![]() ![]() |
I have the Yellow relay ( it only has 2 pins ) , which means that the Cigar lighters and APS ( Auxiliary Power Sockets) are always live when I remove the keys
