Home > Maintenance & Mods (L322) > rear towing eyes
Page 1 of 3 123>
BOBCUSSEN
France 2004 Range Rover Vogue Td6 Java Black
rear towing eyes
i have just bought some dummy tail pipes for my vogue, from powerful.co.uk; and very smart they are too;
they bolt to the towing eyes on the rear, however to my dismay i climbed under to fit them only to find i dont have the eyes fitted ????
the car is a vogue on a nov 2004 plate, and wonder if this is normal and if so if they are a option that an be added???
bob
Post #412078 4th Nov 2016 12:21pm
Weegie
How is your exhaust suspended at the rear? Do you have a tow bar fitted? John
GAP iiD BT
Post #412081 4th Nov 2016 12:40pm
BOBCUSSEN
hi weegie
the exhaust is suspended by a rubber either side and hung from a support either side on the chassis;
no i have no towbar fitted
a couple of pics,
bob
Post #412082 4th Nov 2016 1:08pm
Weegie
I suspect that a previous owner has removed a tow bar and, not still having the original parts, has had those brackets made up.
To replace the originals means removing the rear bumper.
Where in the Dordogne are you? John
GAP iiD BT
Post #412086 4th Nov 2016 1:30pm
BOBCUSSEN
HI Weegie
ok i see, i am in sarazzac which is just outside Thiviers dept 24800
I guess as these two chassis members i have are pre drilled i could probably last make up a L bracket of some sort to fix to the sides of the existing, then bold the dummies up onto them, as they would still be in a similar place if i had the original towing eyes;
im not too concerned have the eyes for any other reason than to mount the dummies;
bob
Post #412088 4th Nov 2016 1:37pm
Weegie
I am just north of you in Mialet. It would probably be easier to do what you suggest rather than replacing with originals. I do have a set which came off when I fitted a towbar. John
GAP iiD BT
Post #412090 4th Nov 2016 1:44pm
BOBCUSSEN
well its ok if things go back the way they came off, but i generally find it not the case, !! but i will have a look and see if it would be easy enough to make up aa bracket od some sort
if that doesen't work, perhaps i can get back in touch regarding your set of original's Thumbs Up
bob
Post #412092 4th Nov 2016 1:56pm
Weegie
No problem. BTW, if I may, if you get an aerosol of black stove paint from your local quincaillerie it works very well on the silencer box being heat resistant and is cheap. Can't have shiney new exhaust tips without doing the exhaust box.
Wink Pardon my presumption. Whistle Very Happy John
GAP iiD BT
Post #412093 4th Nov 2016 2:01pm
BOBCUSSEN
yes it does not look good does it and was my intention as you suggested; jus wondering about the originals, looking at the setup i have under the back, are your original eyes two individual pieces, and if so do you think it may be possible to mount them somehow to what i already have so they sit as they would have been, if not originally removed ? Question
just a thought
bob Whistle
Post #412098 4th Nov 2016 2:27pm
Weegie
They are two separate pieces. They are part of the ex-factory fitting. You couldn't mount them to what you have existing. They have a plate which goes up behind the bumper and gives the strength if used to pull something.
The powerful video for fitting the dummy exhaust tips gives an idea. John
GAP iiD BT
Post #412102 4th Nov 2016 2:43pm
BOBCUSSEN
ok john just a thought;
bob
Post #412103 4th Nov 2016 2:46pm
Weegie
Bob, This link shows how they look http://www.ebay.fr/itm/231895201244?rmvSB=...noapp=true John
GAP iiD BT
Post #412104 4th Nov 2016 2:50pm
BOBCUSSEN
ahh ok , yes a bit bigger then i thought
perhaps i will look at the L bracket option first and if that fails; will go down the original route Rolling Eyes
thanks john
bob
Post #412107 4th Nov 2016 3:10pm
miggit
That looks like half a Writter tow.. someone has removed it to disguise that it has towed Rolling Eyes Yesterday I couldn't spell Engineer... Today I are one!
Post #412165 4th Nov 2016 7:16pm
BOBCUSSEN
hi well im sure i can mount something onto these just to mount the sexy dummies from powerful . co .uk
bob
Post #412202 4th Nov 2016 9:46pm
Page 1 of 3 123>
